Author Topic: Cold Weather Issues  (Read 808 times)
Offline CB650 Wolf
Cold Weather Issues
« on: September 30, 2009, 08:25:31 PM »
Does anyone else with a 81 CB650 have issues with starting and maintaining an idle during cool to cold weather. It just dropped down to the low 60's in the mornings here and now if I can get my bike started it wont stay going for long.
√٧oLҒ
Offline w1sa
Re: Cold Weather Issues
« Reply #1 on: September 30, 2009, 09:06:30 PM »
If the bike sits for a lengthy period, you could have trouble starting/initial idle.
The auto fuel cock unit works off vacuum. Enough fuel will not flow to the carbs and intake till bike is cranked/run long enough for the unit to top up the bowls. Hence initial start up/idle may be difficult.
The hard start condition might be compounded by a weak battery charge.
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
« Reply #2 on: October 01, 2009, 01:10:11 AM »
It is well known "habit" of CB650. I cured it quite far by:
1. Iridium spark plugs - probably the best mod
2. Routing the power supply to ignition coils directly from the battery via relay - this way I have always max voltage on the coils.
3. If you have CV crabs, they will have acceleration pump (not sure about mechanical), then BEFORE cranking, do few (4-5) quick twists of the gas handle - this will squirt extra fuel closer to the cylinder and greatly help with start.
Hope this helps.
Welcome to my mountains!
Mountain Chalets
Offline BVCB650
  • Too Much Thin Air
« Reply #3 on: October 01, 2009, 05:36:52 AM »
Put a "milkbarn" heater next to the heads on a timer. Then you have a block heater. 10 minutes of that and it will start up. BTW, it is 28 here this morning.
« Last Edit: October 01, 2009, 05:38:48 AM by BVCB650 »
1979 CB650, 25K miles, recently refurbished
