Author Topic: case splitting cb350f...wow!  (Read 1874 times)
0 Members and 7 Guests are viewing this topic.
cb350f_dave
« on: September 30, 2009, 08:48:08 pm »
Ok, I know that I should have waited until I had a manual...
but I didn't.
I took on the task of splitting the case on my CB350f motor
and I am sure there must be an easier way to do it.
The chain cam was hooked onto the bottom of the crankshaft
and the two bolts that remove the chain cam cannot be removed
until the case is open. My neighbor and I tried furiously to remove
the case until we finally resorted to removing the clutch, c clip,
bearings, gear shaft, gears, etc.
After about an hour of scratching our heads with our dirty, greasy
heads we finally managed to get it a part.
I'm sure we must have worked bass ackwards.
I hope it goes back together much easier.
Also, does anyone know if the hinge on the chain cam is supposed
to move freely/easily? Because the one we took off was very stiff
and does not move easily...I'm thinking that might have been part
of the problem.
Offline mystic_1
  • 1970 CB750K
Re: case splitting cb350f...wow!
« Reply #1 on: September 30, 2009, 11:43:16 pm »
- John Augustus Shedd
cb350f_dave
« Reply #2 on: October 01, 2009, 08:07:21 am »
Manuals here:
mystic_1
WOW! This forum is the best thing ever!
Thanks mystic_1 if I'd known that was available
it would have saved me a lot of time.
Offline fmctm1sw
« Reply #3 on: October 01, 2009, 03:44:52 pm »
You mean the tensioner?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
cb350f_dave
« Reply #4 on: October 01, 2009, 04:18:10 pm »
I mean the "chain tensioner" or part# 14500-333-020 ...sorry  :(
Offline fmctm1sw
« Reply #5 on: October 01, 2009, 07:10:36 pm »
It should move freely.  That's one of the problems with the 350/400Fs.  I have a post here with a photo of grooves dug into a cam chain tensioner by the cam chain...
http://forums.sohc4.net/index.php?action=dlattach;topic=57399.0;attach=88047;image
« Last Edit: October 01, 2009, 07:14:14 pm by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
cb350f_dave
« Reply #6 on: October 01, 2009, 07:23:40 pm »
That's funny because I have grooves in mine too. Apparently those are
hard to find, so I guess I'm going to have to reuse it.
« Reply #7 on: October 01, 2009, 08:29:18 pm »
Re Use it by all means but make it free first, There is a member on here (ttr400 i think) who does something with those horseshoe tensioners.
ALSO make sure the clamp bolt is free and threads good whilst engine out/apart
cb350f_dave
« Reply #8 on: October 01, 2009, 08:33:07 pm »
"clamp bolt"?
« Reply #9 on: October 01, 2009, 08:45:09 pm »
The one that clamps the push rod that moves the horseshoe
cb350f_dave
« Reply #10 on: October 02, 2009, 10:21:11 am »
oh yeah...ok
Thanks
