Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
so just make sure the tip of the plug is touching a bolt and hit the starter? thats pretty much what I was thinking. thanks
I understand all that. What makes the plug not fire? What stops the spark? To me, a weak spark outside the chamber is a weak spark inside. A strong spark outside is strong inside.
great info as usual. i tried doing it the old fashioned way and the spark seemed a little weak on all four cylinders. i'll have to test coils and wires to see if ther up to spec.
