Author Topic: Couple of questions:Fork mount speedo info/Steering damper  (Read 4217 times)
Tham
« on: October 01, 2009, 11:05:23 AM »
Hey everyone.
I hope I am not screwing up protocol as I searched for these on here.
I was have trouble narrowing down the info.
I want to mount a fork leg speedo to my 74 CB 550.
1. Where are you sourcing the small speedo's?
2. What cable did everyone use?.....any tips,sources for a premanufactured one?....Or how I go about making a reliable & good looking one myself.
Steering damper:
1. I find the simple ones on ebay but if anyone has a better source please chime in.
2. What are people using for the frame mount?....any links to premanufactured clamps or dimension's to machine one.
3. I see two options on the fork....The aluminum clamp on the fork leg....or....mounting to the bottom of the triple clamp.
Preferences?...Pros & Cons?
Thanks in advance folks.
I already appreciate this place.
Here is my bike.
Offline Operator
  • Someday I will live up to being a
Re: Couple of questions:Fork mount speedo info/Steering damper
« Reply #1 on: October 01, 2009, 11:14:34 AM »
First off ......nice bike
I just removed a steering damper from my 1973 750K3. I will try to take some pictures of the mounts. Mine is a simple bolt on but at the moment I can't picture in my head how it was mounted.  Personally, I haven't noticed a difference in handling, even up to 85-90mph, but at the same time, I am not as aggressive in the corners as some. I did notice that while it was on, I lost a fair bit of my turning radius (made it a pain in the ass to turn it around in the garage)
If ever there was a creator of bastard sons, it is the open road, for she has claimed so many young men yearning for freedom......
1973 CB750 K3
1976 CB400F (Cafe Project)
1979 Yamaha XS400 (Currently up for Sale)
Offline Toxic
« Reply #2 on: October 01, 2009, 12:18:14 PM »
CycleX used to have a small speedo that mounts to the lower right fork leg.
http://www.cyclexchange.net/Honda%20Page.htm
I don't see it on their website any more but I would send them an email in case.
Offline j squared
  • www.iliketogofast.com
    • ILikeToGoFast
« Reply #3 on: October 01, 2009, 12:19:10 PM »
Cycle-X still sells the fork speedo's:
http://www.cyclexchange.net/Honda%20Cafe%20Page.htm , about 1/4 of the way down the page
« Reply #4 on: October 01, 2009, 06:51:56 PM »
Speedo in pic is from Drag Specialties, they probably still have, just need the right ratio (think there is only 2)
 Damper:
 Frame on reinforced part is 1.25 inches, forks are 35mm or 1.378, allow more room if powdercoated.
Tham
« Reply #5 on: October 02, 2009, 09:23:55 AM »
Thanks for the quick responses!
That speedo is probably the ticket, I am writing them this morning.
As for the damper:
I don't have an issue with the dimensions of the frame or fork.(I own a small machine shop)
I am just curious of the orientation of the tapped hole....and the appearance of the "frame" clamp.
I have a Bella corse damper mounted to my thruxton and it has a cast aluminum affair with a very strange shape.
I am unsure if he makes them or sources them from somewhere.
Would be great to see pics of others mounting.
Thanks for the help it is greatly apreciated.
Btw: I have found a properly setup suspension and a damper makes a world of difference. Having had a few tank slappers before. I don't think
y turning radius will be affected if I source a damper with enough travel.
