Author Topic: Broken Slow Jet In Carb Body!  (Read 2262 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« on: October 01, 2009, 02:08:28 PM »
I was screwing in my slow jet and I guess I overtightened it and it broke off inside the carb body. I assume this has happened to someone in the world before.I was wondering what is the best method to get this thing out or do I need to buy a whole new carb body? I was thinking I might try a left threaded drill bit but I have no idea where to find one that is that small.
If anyone has any ideas please let me know!
Its hard to be wrong when you know nothing!
Re: Broken Slow Jet In Carb Body!
« Reply #1 on: October 01, 2009, 02:49:58 PM »
I received a carb set from Ebay that had the slow jet broken off in one of the carbs.
Fear and dread.
I think I found an allen key that just fit into the remaining hole and it unscrewed easily.
No big deal.
Offline CBJoe
« Reply #2 on: October 01, 2009, 02:54:21 PM »
I've seen EZ Outs that are pretty small... but It depends on how recessed the broken part is.
Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline campbmic
« Reply #3 on: October 01, 2009, 03:44:51 PM »
It snapped off flush with the hole it screws into on the carb body.
Offline campbmic
« Reply #4 on: October 01, 2009, 03:59:24 PM »
so I was thinking I would buy some left handed drill bits from Freight tools I was wondering if anyone knew what size I should buy?
Here are the two kits Im looking at getting
http://search.harborfreight.com/cpisearch/web/search.do?keyword=left+handed+drill+bits&Submit=Go
The cheaper has a 1/8in
The more expensive one has a 1/16in
Anyone know if either one will work?
Offline campbmic
« Reply #5 on: October 01, 2009, 07:42:58 PM »
bump (if thats allowed)
Offline Johnie
« Reply #6 on: October 01, 2009, 08:32:49 PM »
I had this happen once. Used a very small flathead screwdriver. Gave it a couple light taps on the broke off brass and it came out very easy.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline tlbranth
« Reply #7 on: October 01, 2009, 08:34:52 PM »
Same thing happened to me. Don't remember what I used to get it out but it was easy to do and whatever tool I used was on the bench at the time. I kinda think it was a small phillips screwdriver. It should have almost no resistance to being turned.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
