Author Topic: Is this piece necessary?  (Read 1842 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: October 01, 2009, 08:07:05 pm »
What purpose this serve on the forks? It holds the blinker bracket, but other than that its just a rust hotel on my bike. Can I leave it off and just leave the upper fork uncovered?
Offline mystic_1
  • 1970 CB750K
Re: Is this piece necessary?
« Reply #1 on: October 01, 2009, 08:23:21 pm »
They're holding your headlight on too.
JC Whitney has these for about 12 bucks:
mystic_1
- John Augustus Shedd
Offline robdrobd
  • Who? Me?
« Reply #2 on: October 01, 2009, 08:26:46 pm »
mystic_1
So with those $12 brackets I can get rid of the whole piece without any problems?
Offline robdrobd
  • Who? Me?
« Reply #3 on: October 01, 2009, 08:34:56 pm »
eBay frequently has the real thing for only a few dollars more.
I'd like to eliminate the piece all together as I won't be using the stock signals or headlight on my project.
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: October 01, 2009, 08:39:59 pm »
If you have some other way to mount the headlight and signals than you don't need these at all.  Bear in mind however that sometimes Honda skimped on the chrome on the fork tubes in the area that is covered by the fork ears so you may find some rust there, but maybe not.
mystic_1
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #5 on: October 01, 2009, 08:41:23 pm »
i replaced mine with a set of tomaselli headlight ears. anyone know where to get replacement parts for the things?
Mark Twain - Notebook, 1894
Offline MJL
  • Don't listen to me, I'm no
« Reply #6 on: October 01, 2009, 09:07:27 pm »
mystic_1
Those things truly suck and I would never recommend them to anyone.  I had them on my 650, sure they worked at first but then the screws would come loose and fall out, or the latch part (tab) would come out, etc.  Once the screw came out of the left one and the clamp part fell off, never to be seen again. I rode like that for a few years until I got tired of my headlight vibrating all over the place and I made some heavy duty ones that'll never give me problems.
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: October 01, 2009, 09:10:30 pm »
I had them on my 750 for years without problems, of course I had lock washers under the nuts.
mystic_1
Offline w1sa
« Reply #8 on: October 01, 2009, 09:10:50 pm »
There are a few different ones available. If you are determined to use store bought ones, try and use a set supplied with the rubber? sleeves (minimises vibration/ shock) that go between the bracket and the tube... :)
Offline BlindJoe
« Reply #9 on: October 01, 2009, 10:54:13 pm »
well if thats the case then no you dont need them, leaving the upper fork uncovered wont be an issue
Offline jdubb1977
« Reply #10 on: October 01, 2009, 10:58:16 pm »
i bought the headlight brackets like the ones you're looking at off of bike bandit.  have had them on for about 2 months now w/o any problem.  i used the 2nd holes back to mount my blinkers, and they've worked great.  and for $12, it's worth a try.  i agree that using some rubber between the clamp and the fork is a good idea...although i didn't do it myself.  ;)
Offline Inigo Montoya
« Reply #11 on: October 02, 2009, 06:14:28 am »
I have been thinking about them ears too. Something to get rid of my pitted stock parts.
Offline j squared
  • www.iliketogofast.com
    • ILikeToGoFast
« Reply #12 on: October 02, 2009, 07:17:15 am »
Me three, looking for a different style though.  I see those on a lot of bikes.
« Reply #13 on: October 02, 2009, 08:02:40 am »
if you remove them and forks are not chromed all the way up, we used to;
paint the tops
chrome the tops
 use aftermarket chromed fork tubes.
 not sure on the 550 but on late 750s the fork was available with hardchrome all the way up.
Offline robdrobd
  • Who? Me?
« Reply #14 on: October 02, 2009, 09:00:29 am »
paint the tops
chrome the tops
That was my next question. It shouldn't be a problem if I removed the rust and paint the tops of the forks, correct?
Offline mystic_1
  • 1970 CB750K
« Reply #15 on: October 02, 2009, 09:16:19 am »
Not really, just be careful when remounting things so as to not muck up the paint.
mystic_1
Offline robdrobd
  • Who? Me?
« Reply #16 on: October 02, 2009, 09:51:52 am »
Does anybody want them after I take them off?
Offline FargoFour
« Reply #17 on: October 02, 2009, 02:52:14 pm »
I'll take em off your hands.
What are your plans for the turn signals?
Actually, the whole setup. I have a 750K7 that needs the headlight bucket, ears and turn signals.
bud.
« Last Edit: October 02, 2009, 02:55:02 pm by FargoFour »
Offline robdrobd
  • Who? Me?
« Reply #18 on: October 02, 2009, 04:07:52 pm »
bud.
If you want the ears and signals just pm or e-mail with a reasonable offer. I am keeping the HL bucket for now. thanks
Offline mystic_1
  • 1970 CB750K
« Reply #19 on: October 02, 2009, 10:25:52 pm »
bud.
You can have this one for $20, shipped:
http://forums.sohc4.net/index.php?topic=57322.0
PM if interested.
mystic_1
