SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Go Dwn on clips on Needle or bigger Jet
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Go Dwn on clips on Needle or bigger Jet (Read 919 times)
76supersport750F
Guest
on:
October 02, 2009, 07:41:55 am »
Hello I have a 76 750F Rebuilt carbs and the engine pulls and has power up to 5K.
After that when I hit the throttle it lacks acceleration, breaks down, little popping.
I drive it between 4 and 5K and short shift and it works great. Not very good for the highway passing or getting out of the way quick.
I have the needles to Middle position and the Jet is 120.
Will going down 1 or 2 clips on needle cure this? How and What difference does adjusting
these needle actually make.
Is it best to just put in a 125 jet keeping the clip in mid position and will this cure my lean situation. The plugs looked white on the tips.
Can someone from experience same me the time of taking the carbs off and on two or three times.
Thanks and bye for now.
Logged
mmtsquid
Hot Shot
Re: Go Dwn on clips on Needle or bigger Jet
Reply #1 on:
October 02, 2009, 08:33:53 am »
I can't speak for your bike, but I would recommend ignoring the needle position for the moment and getting the plugs tan at WOT.
Once you have that, then start worrking your way backward (needle position, air/fuel screw, possibly pilot jet).
Logged
77 CB550K4
HondaMan
Someone took this pic of me before I became a
Really Old Timer ...
...not my choice, I was nicknamed...
Reply #2 on:
October 02, 2009, 08:55:26 am »
Your symptoms sound more like a vacuum leak than a carb jetting issue. Try improved hose clamps on the carbs and at the head: the jetting you have should be about right for the "F", if not a little on the rich side already. You may need new hoses.
Logged
Link to Hondaman Ignition:
http://forums.sohc4.net/index.php?topic=67543.0
Link to My CB750 Book:
https://www.lulu.com/search?adult_audience_rating=00&page=1&pageSize=10&q=my+cb750+book
Link to website:
www.SOHC4shop.com
david 750f
Expert
1976 CB750F
Reply #3 on:
October 02, 2009, 09:28:19 am »
Stock main jets on a 750F are 105's. Did you do any engine/exhaust modifications? I agree with Hondaman, check for vacuum leaks. Is your fuel petcock flowing properly?
Logged
1976 CB 750F
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
