Author Topic: Did I miss something on Carb rebuild  (Read 1295 times)
76supersport750F
« on: October 04, 2009, 03:51:35 PM »
Hello How are things? Good I hope.
I rebuilt carbs on 76 750F.
The Idle and off Idle to mid range works ok.
Open the throttle quickly and it hesitate and backfires, back off throttle and it goes ok with little power.
I ran down the highway at WOT  80 miles an hour and shut the engine off and coast to a rest area.
Pulled # 4 plug and it was plain white not anything at all.  Pulled # 1 plug and found a little tan on a small part of the insulator.
This is what I check.   I check for vacuum leaks.  I check points and timing.  I even took off the muffler to ensure that it was not blocked and causing back pressure.  When I took it for a ride without the muffler you could really hear it backfire and break down and no power.
So I quess I must of missed something in rebuilding the carbs.  I have the Needle in mid position and 120 jets.
Did I miss a port that I have to clean out?
I do not know the history of the engine and there may be something change inside.
Would Coils  break down only on a higher rpm 5K .
The bike starts with Chock and Idles fine. You can rev it up and it will go back to Idle.
I wish I had other carbs to try.
Well  I could remove the carbs and change the needle and jet, I could replace coils, wires , etc.
I guess I  have to go with the plug result and change the color first.
Before the carb rebuild the Idle circuit system ran rich.  Because of that the higher rpm breakdown was not as noticeable and the plugs were dark sout.
I went from one extreme to the other.
Well shoot me a thought.
Thanks
76supersport750F
Re: Did I miss something on Carb rebuild
« Reply #1 on: October 04, 2009, 04:42:25 PM »
I read about a 350F having some  higher rpm problems and he  adjusted his float level.
Offline tomkimberly
« Reply #2 on: October 04, 2009, 05:46:13 PM »
Did you replace the jets during your carb rebuild? If so, did you use OEM or some kit? If a kit, what brand?
Tom
76supersport750F
« Reply #3 on: October 05, 2009, 02:05:25 AM »
The Kit I installed is a Keyster.
Too me it looks like I have to make sure my float level is good and I have gas in the bowl.  I will check this out by taking a bowl off the bike and operating it manually.  If the gas is not enough in there I could get this situation.  Also check the pilot jet and make sure all passages are clear as I though I did on the rebuild.
Then I should just move the clip to get more fuel in the intake.
If this is a off needle jet kit than the standard clip position will not work.
What do you think.
76supersport750F
« Reply #4 on: October 05, 2009, 07:45:10 AM »
Hello Tom
Are you going to tell me that the after-market Main jet and Needle and Needle jet are not in spec's compare to the Honda parts OEM?
Have you had this happen to you and did you first try to adjust the Needle to compensate for  it.
I will know more after testing all the fuel system for flow and restrictions.
Offline tomkimberly
« Reply #5 on: October 05, 2009, 08:22:11 AM »
You are correct, they are not the same as the OEM ones.
The brass parts rarely wear out, they just require a good cleaning.
BTW, did your remove and clean the emulshion tubes?
If it was me, I would clean the old jets and needles and use them instead of the ones that came with the kit.
Tom
« Last Edit: October 05, 2009, 08:25:02 AM by tomkimberly »
Offline BeSeeingYou
« Reply #6 on: October 05, 2009, 06:02:22 PM »
Stock airbox and exhaust?  If so 120's seem a bit on the big side 105's being stock.
