Author Topic: CB160 - Can't get rocker arm studs out... Suggestions? PICS  (Read 2137 times)
Offline OakBehringer
« on: October 05, 2009, 09:55:17 AM »
The first one slid right out, the other three won't budge? Any suggestions/secrets to this?
The red stud is what I'm trying to get out. There's really no way to whack it from the other side as the cam chain gear blocks anything you'd try to stick through.
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline tbpmusic
Re: CB160 - Can't get rocker arm studs out... Suggestions? PICS
« Reply #1 on: October 05, 2009, 12:03:51 PM »
On a 175 at least, you can screw a 6mm bolt into their ends and pull them out.
I haven't seen a 160 in many years, maybe it's the same??
Bill Lane
« Reply #2 on: October 05, 2009, 02:37:46 PM »
Nope, but I got them out with a lot of hammering, extension studs, and painful angles not worth describing.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline tomkimberly
« Reply #3 on: October 05, 2009, 05:00:04 PM »
Have you tried a valve spring compressor clamp and a tube to envelope the stud?
Tom
« Reply #4 on: October 05, 2009, 07:43:23 PM »
Try a piece turned to slip in with 10 thou clearance, then drill & tap it then cut it at about a 60 degree angle. then drill the remainder oversize and tighten with an allen bolt and pull it out.
 The part you cut off has to be about 1/2 or 3/8 on the shorter side....it will look like what holds an old bicycle handlebar stem in.
 If it is a blind hole, turn a piece of bar stock to about 3 thou clearance, put some grease in the hole, slide the bar in till it bottoms on the grease, now smack it with a hammer..
« Reply #5 on: October 08, 2009, 11:43:22 AM »
Adam, there's nothing in the Haynes manual that tells how to get them out.
They go into blind holes with the outer covers to stop them coming out.
I'm not sure what would cause them to stick unless the bike has been stored for a long time.
Sam. ;)
« Reply #6 on: October 08, 2009, 12:10:17 PM »
Whoops nm.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
« Reply #7 on: October 08, 2009, 12:12:03 PM »
It might be worth pointing out that they are not blind holes -they're through holes. I can take pics if need be; regardless, I got them out.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
« Reply #8 on: October 08, 2009, 12:39:16 PM »
What stops them going into the cam tunnel, is there a lip on the end.
My motors have 2 through spindles with circlips on both ends, cam tunnel is to the left of the cylinders.
What might have been holding the tight one, did you have a valve that was still on the cam.
That would have put pressure on the spindle.
Sam. ;)
« Reply #9 on: October 11, 2009, 04:57:48 PM »
Sam. ;)
There is no lip. What stops them is actually the studs (the long ones that hold the cases to the block to the head). Not sure if it's just this motor, but they were REALLY tight in their holes.
I'm locking this thread to keep the conversation in a single build thread, found here:
http://forums.sohc4.net/index.php?topic=59891.0
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
