Author Topic: Speedometer really slow to show speed  (Read 899 times)
Saml01
« on: October 06, 2009, 08:26:55 PM »
I noticed today that my speedometer is really slow to show the indicated speed, and I have a feeling it may be entirely off too.
How fast should these ancient speedometers work?
My tach is instantaneous, I would imagine the speedo should be similar.
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Re: Speedometer really slow to show speed
« Reply #1 on: October 07, 2009, 09:22:30 AM »
With age, the oil inside gets stiff and dirty and acts as a drag on the magnet and drum. I had to have mine refurbished.
Fonda Honda
Saml01
« Reply #2 on: October 07, 2009, 12:49:44 PM »
Got any more info on that?
I got a second set of instrument in a box, and if youre saying its not supposed to work so poorly ill try the other.
Offline Alan F.
« Reply #3 on: October 16, 2009, 06:44:52 PM »
have you lubed your speedometer cable at all? with age the same old oil and old dirt can cause it to bind. it's possible to remove the cable fro m it's housing, it slips out the speedometer end if I remember correctly.
remove both ends of the cable assembly, remove the cable itself from the jacketing, place one end in a jar and spray wd-40 or something down through the housing to clean out all of the old lube and crud. when the wd-40 begins to come out clean...you're done. clean the cable with more wd-40 and a clean rag then reinsert it into it's jacketing and attach it to the speedometer and the speedometer drive and go test it out.
it may not be the cause, but speedometer cables sometimes will be broken inside their jacketing, they'll read sporadically sometimes or just not read at all, this way you'll know for sure.
-Alan
