Author Topic: Motion Pro Carb Sync Manometer SUCKS  (Read 27928 times)
Offline Slayer
  • What can I say that hasn't been said before
Re: Motion Pro Carb Sync Manometer SUCKS
« Reply #50 on: November 17, 2009, 10:54:35 AM »
If I lowered the idle enough for the vacuum to be in the sync tool's range, the engine would not run. It was idling at about 1,100 RPM's. I was following the service manual for adjusting the idle mixture by turning the idle mixture screw in until it reaches the highest RPMs, adjust idle speed with the stop screw, back it off 100RPMs, turn the screw back out 1 1/4 turns, and readjust the throttle stop screw back to 1,100 RPMs. I did this with a bench sync and no dice. Once I built a manometer with a higher range and synced it, it was still running bad so I reset the IMS back to 1 3/4 turns out and am trying to figure out the problem now.
captainchadl
« Reply #51 on: November 17, 2009, 05:16:15 PM »
are you adjusting the pilot screws or syncing the carbs
Offline Slayer
« Reply #52 on: November 18, 2009, 10:09:52 AM »
Neither. I did the adjust and the sync, now I am troubleshooting the problem with cylinder #2 not running
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #53 on: November 18, 2009, 04:22:45 PM »
sounds like a problem with your idle circuit... I had the exact same symptoms when trying to sync mine up. The o-rings under my pilot screws were in really rough shape. Replaced them and no problem at all.
Present: 1978 CB750A, 1978 CB400A, 1983 Nighthawk 550, 1984 CM250C
Past: 1977 XL100, 1982 KZ1300
