Author Topic: will this tool be suffiecient to split the cases on a cb 550  (Read 2224 times)
Offline elquenada
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
Offline NickC
Re: will this tool be suffiecient to split the cases on a cb 550
« Reply #1 on: October 08, 2009, 12:15:24 PM »
Unbolt everything and give it a few encouraging whacks with a rubber mallet.. ??? ???
Offline bistromath
« Reply #2 on: October 08, 2009, 12:23:53 PM »
Yeah you shouldn't need any special tools. Just make sure you get ALL the bolts out, including the sneaky one inside under the oil pan. Then like Nick said you should be able to whack it around the edges with a rubber mallet to loosen things up, and then separate the cases. I did take a dowel and place it under the points housing and whack upward a bit to convince things to move.
'75 CB550F
Offline elquenada
« Reply #3 on: October 08, 2009, 03:13:39 PM »
thanks for the info. glad to hear that I wont need to dump even more money into this project ;D
1975 CB 550
Lope de Vega
« Reply #4 on: October 08, 2009, 10:56:24 PM »
That tool is for splitting the vertically split crankcases, usually single cylinders
« Reply #5 on: October 09, 2009, 07:49:58 AM »
I think you should start reading a manual..
 The one that looks like a book, not a pdf file..
 Read it, re read, it, then look at it some more..
and pretty soon you will know what you need..
Offline elquenada
« Reply #6 on: October 09, 2009, 08:56:41 AM »
thanks for the tip but I dont think thats my problem.  1 practically sleep with my clymer manual in hand but I find it to be quite vague.  The pdf file I have of the original Honda Manual is not that explicit either and the pictures aren't very clear.  I cant seem to find and original print of the manual.  do you know someone who sells one?
1975 CB 550
Lope de Vega
Offline lordmoonpie
    • Moonpie
« Reply #7 on: October 09, 2009, 08:59:41 AM »
Get yourself a Haynes manual off ebay - miles better than the Clymers which I agree are super vague, usually in the places you need them not to be!
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline The_Crippler
  • Work in progress.
« Reply #8 on: October 09, 2009, 09:25:55 AM »
Never tried the other brand...but I totally agree on Clymer.  They are often like:
1.) Remove screw (fig 1.a screw)
2.) Lift seat off (fig 1.b the seat)
3.) Remove battery, drain oil, remove engine housing, rewire oil sender unit and neutral control while removing chain and rear tire. (fig 1.c the bike.)
Offline camelman
  • Man... Myth... Legend
« Reply #9 on: October 09, 2009, 10:05:24 AM »
Awesome!  don't forget:
4) reinstall in reverse order of removal while following appropriate torque specs (without torque specs being given anywhere in the book).
Those cases come apart pretty easily.  If they are not budging, then you likely have not removed all of the bolts.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Fritz
« Reply #10 on: October 09, 2009, 01:38:59 PM »
The shop manual says that a special tool (slide hammer) is to be used to pull out the primary shaft.
I'm planning to change the primary chain on my 550. Is this tool really required or can it be done without, keeping the bearing intact?
1976 CB550F
Offline NickC
« Reply #11 on: October 09, 2009, 03:17:35 PM »
You can easily tap it out from the opposite side....
Offline Fritz
« Reply #12 on: October 09, 2009, 03:22:33 PM »
Ah thanks!
Should have used "search" before asking. I've just learned that the lower rear engine bolt can be used to pull the shaft out
http://forums.sohc4.net/index.php?topic=42910.0
1976 CB550F
Offline bistromath
« Reply #13 on: October 10, 2009, 12:40:37 PM »
I just used a wooden dowel and tapped it out from the opposite side, on the oil pump gear. Use a thin (1/4") wooden dowel. Easy as pie.
'75 CB550F
« Reply #14 on: October 10, 2009, 12:59:34 PM »
There is far gentler things to use than a chisel. :o
 put a bolt or stud in the motor mounts top & bottom and pry  or wedge them apart.. dont use the motor mount above the sprocket side, to do this..
