Author Topic: Clubman or clip-on for Cafe Build  (Read 36795 times)
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Re: Clubman or clip-on for Cafe Build
« Reply #25 on: October 13, 2009, 01:23:23 PM »
There's a better pic of a set of Dunstalls clip ons(or style) mounted on a bike in the "projects section". I cant find it, but its the cafe bike with a large sissy bar on it.
This the one you're looking for?
  Yes, Here's the pic showing the clip ons
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline The_Crippler
  • Work in progress.
« Reply #26 on: October 16, 2009, 11:15:38 AM »
Here's another two questions, as I've never installed these.
What do you have to do to install these above the top tree on a CB650C? (Is there a special aftermarket tree top/connectors needed?)
How do grips and bar-end mirrors work?  Are their special grips with an open end? (These are the type of mirrors I'm looking at.)
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« Reply #27 on: October 16, 2009, 11:57:51 AM »
They do make grips with an open end.  I don't remeber what company I saw that had them but my 550 had some.  I think it was spider if I remeber right.
Keep it shinny side up.
  • Work in progress.
« Reply #28 on: October 16, 2009, 12:19:31 PM »
Does that mean that they're not the standard, though?  What is done in the other cases - do you just lop the ends off standard ones?
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #29 on: October 16, 2009, 12:40:27 PM »
get this type of clip-on
  replace the straight bar with a piece of 7/8 pipe with a bend 2 inches from the end
    and you have adjustable rise/pullback.
  • Like a well oiled
    • Undead Asphalt
« Reply #30 on: October 16, 2009, 12:46:56 PM »
tomaselli makes some bars that attach to the top nut, they're raised and bent for adjust ability.
Offline Shenanigans
  • Right turn?
« Reply #31 on: October 16, 2009, 01:01:09 PM »
Just cut a hole in the end. Cheap easy and they look cool.
Offline fishhead
« Reply #32 on: October 16, 2009, 03:12:40 PM »
 Same type of idea, but instead of bending a straight tube, just get a typical "drag" bar and cut it in half and use 1 half for each side. You can also mount the clip on clamps on the wrong sides/upside down (so they point up) to get even more adjustability out of them.
  • Like a well oiled
    • Undead Asphalt
« Reply #33 on: October 16, 2009, 03:43:45 PM »
good idea fishhead.
  • Work in progress.
« Reply #34 on: October 16, 2009, 05:19:06 PM »
Good information, everyone.
So, all the mods for above-the-tree clipons seem to say that it's not the "right" way to go about it.  That's cool...learning as I go.
Does the top of the tree clean up nice, or does removing the existing bars leave unused mounts and such that can't be removed "nicely"?
  • Like a well oiled
    • Undead Asphalt
« Reply #35 on: October 16, 2009, 05:47:09 PM »
you'd have to cut them off.
  • Work in progress.
« Reply #36 on: October 16, 2009, 05:49:59 PM »
Which is unfortunate.  Looks like another case where the 650 people get screwed.  I know they make billet tops for the trees on models look the 400, but nothing I've found for mine.
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #37 on: October 16, 2009, 06:12:43 PM »
also for bar end mirrors I saw this and just orderd it since I have roost guards on my dirtbike and found this to make it easy for grips.
http://www.motionpro.com/motorcycle/partno/08-0335/
  • Work in progress.
« Reply #38 on: October 16, 2009, 07:12:08 PM »
Hey, that's pretty slick...is the idea that you cut from the inside of the grips?
Here are some I'm thinking of, as they are very similar to my Vulcan's, which I love.
http://www.motorcycle-superstore.com/1/4/68/4659/ITEM/Pro-Grip-860-Foam-Cruiser-Grip.aspx?SiteID=SLI|Grips&WT.MC_ID=10010
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #39 on: October 17, 2009, 06:29:42 AM »
Yea you just put it on the intisde of the grip and hit it with a hammer and it cuts a perfect hole.   The local bike shop has it and says it works great.
Offline Flying J
« Reply #40 on: October 17, 2009, 11:25:05 PM »
i just use a rubber mallet on the end of my handlebars when i install them.
  • Like a well oiled
    • Undead Asphalt
« Reply #41 on: October 18, 2009, 06:39:33 AM »
yeah me too.
                                right tool for the job be damned!
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #42 on: October 18, 2009, 11:46:07 AM »
I might actually steal that idea. I like that a lot. I was planning on mounting clip ons above the trees, cuz the gl front end is a little longer I believe, so I have room. I'll cut, grind, sand off the handlebar mounts and I want to put led idiot lights in the 4 holes that will be left behind. another idea from someone else here. sorry, I forgot who.
as my front end is now I grinded, etc off the gauge mounts. I have the fork mount speedo from cycleX. anyways it (triple tree) cracked. no biggie, I'm not using it, but I'm wondering if it was the removal of the mounts that weakened it for it to crack. could also have something to do with a bent fork tube.
  • Like a well oiled
    • Undead Asphalt
« Reply #43 on: October 18, 2009, 01:50:25 PM »
hey Greasy J-
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #44 on: October 18, 2009, 02:25:59 PM »
hey Greasy J-
took me a minute. funny. I wasn't sure the best way to spell aarrrr. it's like the old joke how does a pirate watch movies? on a vc aarrrr.
  • Work in progress.
« Reply #45 on: October 19, 2009, 03:40:44 PM »
Hmm...I'd take it then that this would only work with rubber grips, right?
Looking more like I'm going to have to go with clubman bars afterall...I hadn't fully realized that the headlight ears on mine are not easily removable.  Looks like I'd have to grind them off.  (This is, of course, discount doing a full front-end swap, which I don't have the know-how to figure out one that would work.)
  • Work in progress.
« Reply #46 on: October 21, 2009, 08:27:12 AM »
Does Tomaselli have a homepage?  I can't seem to find it.  The Googles just give me hits for forums or 3rd-party sellers.
Offline Geeto67
  • A grumpy
« Reply #47 on: October 21, 2009, 05:18:37 PM »
hey crippler...what are you doing about footpeg position? unless you want your bike to be the crippler you need to think about your body position as a whole not just throw a set of low bars at a bike and presto insta-cool, doesn't work that way.
BTW, if anybody wants clip-ons with a superbike bar bend, I have a shipment of such on its way to me. should be here in a couple of weeks.
Maintenance Matters Most
  • Work in progress.
« Reply #48 on: October 22, 2009, 06:48:07 AM »
I'm planning on rearsets.  I haven't found anything made specifically for 650s, but there are some universal sets that i've been looking into to see if they'll work.  If I can't find anything that will get the job done, the second idea is to see if I can find anyone that can fashion a set.  If that also falls through, I'd probably be scrapping the cafe idea - but i doubt that it will come to that.
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #49 on: October 22, 2009, 08:21:09 AM »
For rearsets you could fab up a mount for a universal set.  I'm gonna go that rout since I can't find any for a 550f  going to buy a set for a cb400 I found onlinen that look clean and make my own mounts.
