Author Topic: I've looked can't find vendor for CB750 wheel bearings  (Read 3026 times)
« on: October 10, 2009, 08:54:57 AM »
Hello: Ideas for traditional vendor, like motogrid, or bikebandit, someone I can order from, for double sealed rear wheel bearings for CB750.
Likely they are available locally from a bearing supply, but I'm not free to travel around for a week or two. I could order them in by then.
Yamiya shows NSK bearings but can't tell if they are doublel sealed. I have sent them an inquiry.
TIA.
Offline mystic_1
  • 1970 CB750K
Re: I've looked can't find vendor for CB750 wheel bearings
« Reply #1 on: October 10, 2009, 09:09:14 AM »
Z1 has them
For the wheel, Wheel Bearing - 6304-2RS:
http://www.z1enterprises.com/detail.aspx?ID=2840
For the sprocket carrier, Wheel Bearing - 6305-2RS:
http://www.z1enterprises.com/detail.aspx?ID=2841
mystic_1
- John Augustus Shedd
« Reply #2 on: October 10, 2009, 09:26:38 AM »
You can order SKF from MSC Supply. Cream of the crop!
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: October 10, 2009, 09:56:53 AM »
Pricey!  Will these just last longer or are there other benefits?
6305 2RSJEM:  http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=22338572&PMT4NO=72229016
6304 2RSJEM:  http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=22338569&PMT4NO=0
mystic_1
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #4 on: October 10, 2009, 10:03:16 AM »
bikebandit.com has 'em, great prices and service in my experience.
6304 - $16
6305 - $17
i was in a hurry once and stopped into a local bearing shop for a rear wheel bearing, had an skf for $54.  since i disass/lube wheel bearings in the off-season, i cheaped out.
bobp
searching for a dr350se
Offline Alan F.
« Reply #5 on: October 10, 2009, 10:23:31 AM »
All-Balls probably has a kit complete with seals.
« Reply #6 on: October 13, 2009, 07:24:02 AM »
mystic_1
The SKF metals are nearly as hard as the old Timkens, which I still have in my 750 after 100,000 miles. I have no detectable wheel looseness (none) from those bearing, yet! I paid $40 in 1972 to get them, so the SKF prices don't seem out of line, to me. But, I'm picky, and like a tight-handling bike...
