Author Topic: What motor oil should I use?  (Read 5371 times)
Offline Simpson
  • I ain't no
  • Aged to perfection
Re: What motor oil should I use?
« Reply #25 on: October 12, 2009, 04:04:58 PM »
Jerry, Castrol GTX 20-50w sounds great, thank you!
Two Tired, I don't have an owners manual and figured there might be something better suited to a 33-year old bike than what the manufacturer suggested way back when.
Aloha, Mike
Without stirring the pot...
+1 sorta Repsol Syth 20w-50
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Bodi
« Reply #26 on: October 12, 2009, 04:49:24 PM »
Depending on where you are in Hawaii...
It's hottish for sure, but not crazy hot like Nevada in August. You don't have to worry about cold flow, anyhow.
If you're not regularly stuck in Honolulu traffic, I would say any motorcycle specific oil would be great, Honda has oil but it's relatively expensive. If you can find bike oil at an auto store or whatever that should be fine.
If you do a lot of traffic riding, I think a full synthetic would be desirable; they handle high temperatures better than standard oils. Amsoil motorcycle oil is good, and cheaper that a lot of the bike store stuff like Motul and Spectro.
use the weight recommended by Honda, you can go a bit higher on the bigger number (ie 10-40 instead of 10-30) but don't go thicker or thinner on the low number in my opinion.
Sorry about the initial response you got, oil questions bring out some strong opinions.
I suggest that you avoid asking about religion, politics, or gun laws on the open forum as well....
Walktex1
« Reply #27 on: October 12, 2009, 08:15:29 PM »
Wow - wonder why Honda would offer an oil specifically for motorcyles.......mmmmmmmm.... and if yer clutch starts slipping - it probably was the wrong stuff  ::)
Offline lowmileage
  • Gotterdone
  • At Montauk Point Circa 1975
« Reply #28 on: October 14, 2009, 01:09:27 PM »
You mean you need oil  ???
1975 750 K5 Original owner -  11K miles.  On the road 8/09 after 26 years in storage.
2004 Harley Superglide - bought new
1973 Honda CL350 - sold in '75 to buy the "750"
Offline mrbreeze
  • Not your average
« Reply #29 on: October 14, 2009, 02:08:47 PM »
Make sure to look up oil coolers while your thinking about oil . Cooler threads are just as much fun as oil threads . Change your oil often and put the used stuff in your lawn mower . ;)
Why is it that poor old lawn mower always gets it?..........you know....the old gas....the used oil........ ???
MEMBER # 257
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
« Reply #30 on: October 14, 2009, 03:28:57 PM »
I use Castrol 10 w 40 motorcycle oil. Its never gave me any problems in my 74 CB750. I would not use use synthetic in these older vintage motors, although some do. The Honda manual specificley says Castrol 10 W 40 or 20 w 50. I bought a 1997 Honda XR400R brand new and never ran anything but Honda synthetic in it. It never gave me any problems but then again I changed it about every 2 or 3 rides to. I use to do a lot of ridingon it in places with some pretty deep mudholes. Like everyone else said its not that we don't want to help the other guy out but everyone has their own preference. Just pick a good grade of oil and stick with it. Oh one other piece of advice you can order your filters from Advance auto parts and they're alot cheaper than the dealer. I use a Fram in mine. When you change your filter don't throw away the little thin washer that will stick to the filter. The spring sets up agaist it to keep from damageing the filter. Last but not least download the Honda manual from the top of the forum it will save you time and trouble.
People with closed minds cannot learn new things.
Offline wrenchmuch
« Reply #31 on: October 15, 2009, 06:18:03 AM »
Lawn mowers are king at consuming things other engines would cack on . When they do finally die my 10 year old gets to see how it works . Hours of peace  ;D
CB750K1
CB750K4
Offline mrbreeze
  • Not your average
« Reply #32 on: October 15, 2009, 08:17:55 AM »
;D ;D ;D
MEMBER # 257
