Author Topic: 74 CB200 No Compression  (Read 4735 times)
CCypher
« on: October 10, 2009, 11:03:38 PM »
Hiya guys, I recently picked up a project CB200T for next to nothing and have been attempting to get it running again. I've run into quite a snag however, after finally getting the right compression gauge for the job I've come to realize I'm only getting ~60PSI  or so in each cylinder, even after adjusting the valves.
My question to you guys is, are you aware of any other engines that would swap easily, or if there's anything common about these sorts of bikes that I might be able to fix easily and save the engine. I really don't want to have to part this out as it's only got 6600km or so on it.
Thanks!
[edit] After reading the post below mine, I think I may have administered the test wrong. I didn't know you should keep kicking until it tops out. Whoops. I suppose I'll post back if it still doesn't do well.
« Last Edit: October 10, 2009, 11:10:02 PM by CCypher »
Offline Spanner 1
Re: 74 CB200 No Compression
« Reply #1 on: October 10, 2009, 11:18:16 PM »
Was the motor 'stuck' when you got it ?.....if so surface rust in the cylinder walls may have forced the piston rings into their grooves when the motor was turned-over and stuck rings = low compression.........
Offline Hush
« Reply #2 on: October 11, 2009, 01:10:54 AM »
Sometimes (many times) it's user fault when the readings are low, with that mileage it better have a hole in each piston to read so badly.
I'm guessing it's a twin cylinder so try the old "thumb" over the spark plug hole instead, if it has enough pressure to blow your thumb out it has enough to run when gas and spark are added.
Offline patricke9
  • SOHC4 #2037
« Reply #3 on: October 12, 2009, 08:58:16 AM »
Did you have the throttle wide open while testing?  Had the same issue, forgot when testing my CB550 & wound up with really low readings, did it over & compression jumped up t 145/cylinder.
"I did everything by the seat of my pants. That's why I got hurt so much."
Evel Knievel
1978 Kawasaki KZ650
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #4 on: October 13, 2009, 04:06:57 AM »
Why swap engines? You will never know the whole story until you disassemble it. I've picked up many bikes that had low compression. In some cases the rings are frozen in the grooves in the pistons. Sometimes you can remove those rings and clean everything up and reassemble. Now the rings can expand as they should and you have good compression.
Worst case, buy oversized pistons and rebore, that of course assumes it is the rings. You can know very easily if it's rings over valves... You have a compression reading of 60 PSI. Remove the plugs and drop a teaspoon of oil into each cylinder. Take a reading again. If the reading comes up dramatically, you have a ring problem. If it doesn't, you probably have a valve problem.
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
Offline Laminar
  • Retsam
« Reply #5 on: October 13, 2009, 06:26:48 AM »
Seconded.
Offline tbpmusic
« Reply #6 on: October 13, 2009, 08:37:11 AM »
Take your time and do it right - they can end up like this if you do -
http://home.comcast.net/~tbpmusic/id55.htm
Bill Lane
Offline Laminar
  • Retsam
« Reply #7 on: October 13, 2009, 11:34:02 AM »
And if you half-ass your way though everything, it looks like this:
Offline tbpmusic
« Reply #8 on: October 13, 2009, 01:10:27 PM »
Mine was ten times worse than that when I started..........it was a disgusting, rusted out hulk, in that puke yellow they used to come in-ugh.....
Bill Lane
Offline Laminar
  • Retsam
« Reply #9 on: October 13, 2009, 04:28:44 PM »
Here's what mine looked like:
Offline Bodain
« Reply #10 on: October 14, 2009, 06:47:49 PM »
Well maybe it's just me. I like the BLACK rat bike, better than the red shiney one. Who's to say what's right as far as paint and looks go. I think most 70's bikes in stock form are downright UGLY...
2009 Suzuki TU250
2014 Honda Grom
2005 Yamaha Zuma 50
1974 Honda CB 750
