Author Topic: soda blasting  (Read 10551 times)
swiffer
soda blasting
« on: October 12, 2009, 09:36:11 AM »
Ok i have a motor i dont know when i will get back because the guy that has the soda blasting machine does not know when he will get the hoses out and start up the thing again.So i did some checking on a home version of soda blasting on the cheap.I did order this because someone else posted it worked with soda also on another site.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100008764&langId=-1&catalogId=10053&ci_sku=100008764&ci_src=14110944&cm_mmc=shopping-_-googlebase-_-D25X-_-100008764
But also ran across this that i think you may find interesting and should have done myself because i already have all the stuff. http://www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
Offline myhondas
  • Not really such a
Re: soda blasting
« Reply #1 on: October 12, 2009, 09:59:18 AM »
what are u going to blast? the whole motor or carbs or what?
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
swiffer
Re: soda blasting
« Reply #2 on: October 12, 2009, 03:15:33 PM »
Right now ,nothing because the motor and carbs are at the shop where they will get them blasted.The reason i checked on How to do it is because next time i will try myself instead of waiting on someone else.
esw07
Re: soda blasting
« Reply #3 on: October 12, 2009, 04:08:39 PM »
I made something similar to the Soda Blaster in the second link. It worked well for a little while but the time to make it and trouble shoot so it would actually remove rust and corrosion wasn't worth it. I would just pay the $9 for that pre-built Husky from Home Depot.
Also this will not remove paint when using baking soda. I recommend using a cheap powder based laundry detergent if there is some serious grime that needs to come off. Also make sure the parts are as dry as possible, the soda just sticks to any wet spot or clogs up any small openings that are damp.
Re: soda blasting
« Reply #4 on: October 17, 2009, 04:44:59 PM »
I would suggest you place bolts in all of the holes before you blast.
swiffer
Re: soda blasting
« Reply #5 on: October 17, 2009, 06:19:54 PM »
I received that Huskey sand blaster today and for the price it looks like a sturdy piece of equipment.I will try to see if i can get it to work with soda also.
Offline CBGhia
Re: soda blasting
« Reply #6 on: October 17, 2009, 07:17:56 PM »
I have a small cheap blasting gun with a top feed container.  I used baking soda because they only had the 50 lb bag of blasting soda at the harbor freight.  I think I will have to spend the $35 though because baking soda does not work all that well.  Blasting soda is much more coarse.
Offline Blackhorse
Re: soda blasting
« Reply #7 on: November 28, 2009, 08:31:52 AM »
I use the HF 10 lb soda blaster unit with great results. Got it for $79.99 with a 20% off coupon. HF also sells a 15 lb unit.
"The road goes on forever, but the party never ends"
1975 CB550F SS
1979 BMW R100/7
2008 KLR650
