Author Topic: Gas and glass... a weird question  (Read 2026 times)
Offline greenjeans
  • 1972 CB750K2
« on: October 12, 2009, 02:25:32 PM »
A buddy of mine is building a crazy 550 (the guy on Two Guys Garage) and on his custom formed tank he's wanting to add a "site glass" to the side of the tank
through which you could see the fuel level.  The glass is off an old WWII plane of some sort and is really cool.   Can't really figure out how to make this work.
Are there any companies that make a gasket that could seal tight enough to actually work ?    Any brilliant ideas out there ?
esw07
Re: Gas and glass... a weird question
« Reply #1 on: October 12, 2009, 04:22:42 PM »
Just a quick thought that may or may not work. Would it be possible for him to fiberglass up a tank and incorporate the glass viewing window while laying down the layers of fiberglass? I've never done fiberglass so this may just be an out there idea, but when thinking about it this would make the viewing window an actual part of the tank that doesn't need a special seal.
Like I said, I have never done anything with fiberglass so I'm not sure how well this method would seal up the viewing window.
Offline MikeDeB
« Reply #2 on: October 12, 2009, 04:46:31 PM »
Ducati did it on the fiberglass tanks for the '74 750SS.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: October 12, 2009, 05:07:39 PM »
Honda seemed to think that threaded bungs were a good idea.  Before that they used o-ring seals and screw mounting.  Worked well for petcocks.
Got pics?
You'll probably have to add some intermediate fittings to make your specific glass fit.
I've seen pics of site glasses done using copper pipe fittings and clear tubing.  I'm sure that this particular cat has been skinned thousands of times over the year.  What does the all-knowing oracle at Google say?
mystic_1
- John Augustus Shedd
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: October 13, 2009, 08:29:32 AM »
I'll dig around and see it I can find some pics.   The tank will definitely be in metal - that's his specialty.
Keep the ideas swirling....
Offline Gorms
  • Barkeep! Give me a beer and a
« Reply #5 on: October 14, 2009, 08:20:32 AM »
A better idea would be to thread two 90 degree fittings into the side of the tank, one on top of the other with their ends facing eachother.  Put a plastic (or glass) tube between the two and use it as a level gauge.
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: October 14, 2009, 09:08:38 AM »
I think I mentioned that approach :)  Sounds like they have a specific piece of glass they want to use, tho.
mystic_1
Offline MJL
  • Don't listen to me, I'm no
« Reply #7 on: October 14, 2009, 10:50:03 PM »
If it is flat glass you can cut a slot in the side of the tank and make an oval piece to sandwich the glass between, just make some good gaskets or RTV.
