Author Topic: Easy way to properly adjust my headlight  (Read 675 times)
Offline jcarthel
  • K2 Justin
« on: October 13, 2009, 07:31:09 PM »
I think my headlight needs a little adjusting.  The left/right angle seems fine, but I think the light is not pointed down enough.  What is an easy way to properly adjust my headlight I could do in my driveway?
Justin in Texas
Offline GammaFlat
Re: Easy way to properly adjust my headlight
« Reply #1 on: October 13, 2009, 07:39:09 PM »
Grab ahold of the top and give it a push (or pull).  If it's not too tight, you can "wrestle with it" to adjust it.  Technically, you're prolly 'poseda loosen the bolts that hold it, adjust, and re-tighten.  In terms of height, I'm sure there's a recommendation... someone will chime in with how far in front of the bike the light is supposed to be "on" the pavement.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline jcarthel
  • K2 Justin
« Reply #2 on: October 13, 2009, 07:51:41 PM »
Thanks!  Yes, what is a way in my driveway, I can properly check the beam's downward angle to make sure it is right for maximum lighting while riding at night.
Justin in Texas
Offline the technological J
  • deliciouso!
« Reply #3 on: October 13, 2009, 08:04:29 PM »
i adjust mine while going down the road ... i make the highs just barely hit the road.. but whatever u like... to me its all about the highs
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Raul CB750K1
« Reply #4 on: October 13, 2009, 11:49:05 PM »
+1, I adjust mine while riding. Bolts are tight enough to keep the headlight in place, but loose enough to allow for fiddling.
Just get on the road, put low beam and move the headlight up and down until you find the perfect spot where it illuminates enough part of the road and with enough intensity, and then switch to high beam and check that now it is further ahead where the light is going to. Too high and the high beam will illuminate the sky not the road. Too low and the low beam will illuminate the front of your bike, something that is not desirable because you don't ride looking your front wheel.
Obviously, you need some balance to tilt your body to the front of your bike and steer with one hand while you adjust the headlight with the other hand. Do it under your own responsability.
Offline Alan F.
« Reply #5 on: October 14, 2009, 07:12:33 AM »
I'll agree with the other posters, you've gotta set your headlight angle while out on the road on a dark night.  There is no substitute.
-Alan
