Author Topic: Engine Bearing Replacement  (Read 29680 times)
Offline odin836
  • Honda CB750 K3 (...in pieces...)
« on: October 14, 2009, 01:21:27 AM »
Engine Bearing Replacement...
Thought this might help a few people and give me the opportunity to pose a question...  ;D
Has anyone ever had the channel in a bearing for ball bearing setting machined wider to take the stock honda setting (eg. Part 13496-300-000)?  ???
Replacement bearing details.
Primary Tensioner
Honda Code
91004-300-000 - Unavailable
NTN Bearings Code
NTN6008NR
(Channel in bearing for setting not wide enough, will need machining)
Final Drive Shaft
Honda Code
91996-300-008 - Unavailable
NTN Bearings Code
NTN6205
Honda Code
91008-300-008 - Unavailable
KSM Bearings Code
5206
Transmission
Old Honda Code
91002-300-008 - Unavailable
Current Honda Code
91003-612-004 – Available
Current Honda Code
91003-235-000 - Available
Current Honda Code
96100-63040-00 – Available
Current Honda Code
96100-62040-00 – Available
Still to replace the Clutch Bearing, once source I will update this post.
CB750 K3 in pieces.
Offline mick7504
Re: Engine Bearing Replacement
« Reply #1 on: October 14, 2009, 03:32:45 AM »
No, never had any reason to do that and I reckon you'd be flat out like a lizard drinkin' trying to regroove a bearing case.
Aftermarket replacement bearings have never been a problem but you must use the original Honda half moon rings with the grooved bearings.
The grooved bearings generally come with a snap ring on them which are wider (not thicker) than the Honda rings and will go nowhere near fitting into the cases because of the larger diameter.
I'm assuming that this is what you're up against.
Here is a list of SKF bearing numbers that will cover the tranny from the kick starter to the gear lever.
They should be uniform numbers and or able to be cross referenced from all bearing suppliers.
2 x HK2520 Needle Rollers
1 x 3206ATN9 Roller Bearing
1 x 6003 Roller Bearing
1 x 6008NR Roller Bearing
1 x 6204 Roller Bearing
1 x 6205 Roller Bearing
1 x 6205NR Roller Bearing
1 x 6304 Roller Bearing
1 x 6304NR Roller Bearing
The "NR" designates a groove in the outer bearing case.
Hope this helps
If I was you
I'd be worried about me.
Offline Ricky_Racer
« Reply #2 on: October 14, 2009, 09:26:07 AM »
Mick, could you edit/repost your list with a reference to where each of these SKF bearings goes? Thanks, Mate!  RR
Offline odin836
« Reply #3 on: October 14, 2009, 03:34:30 PM »
Yes, a description of what each bearing is for would certainly help...
Cheers
CB750 K3 in pieces.
Offline mick7504
« Reply #4 on: October 14, 2009, 04:33:29 PM »
No problem at all guys.
I only have a list of part numbers that I have used previously on hand at the moment and haven't catalouged where each one goes but that shouldn't be a problem.
I'll see if I can scan in an exploded view of the tranny with the part numbers next to each bearing.
What I can do in the meantime is give you the ID/OD and width of each bearing which will be a start at least.
Nailed to the floor with other work at the moment and will get onto that as soon as.
If I was you
Offline Ricky_Racer
« Reply #5 on: October 14, 2009, 04:39:39 PM »
Thanks, Bro! RR
Offline mick7504
« Reply #6 on: October 15, 2009, 05:51:00 AM »
Here goes.
Some exploded views and the bearing numbers and sizes. OD x ID(Bore) x Width.
These are all SKF part numbers.
The "NR" after the number means that there is a groove in the outer bearing case.
Most bearing suppliers should recognise these part numbers although it is a good idea to always double check first before purchasing.
« Last Edit: April 23, 2018, 04:30:37 AM by Glenn Stauffer »
If I was you
Offline odin836
« Reply #7 on: October 15, 2009, 03:50:51 PM »
Thats great!
I'm sure this will help many people, esp since not all parts are available from Honda...
CB750 K3 in pieces.
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: October 15, 2009, 09:08:54 PM »
That should be added to the FAQ!
Thanks!
mystic_1
- John Augustus Shedd
Offline odin836
« Reply #9 on: October 16, 2009, 07:54:58 PM »
Whats the trick for removal of the HK2520 Needle Rollers from the Primary Drive?
Please dont tell me its a Honda Speciality Tool :(
CB750 K3 in pieces.
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: October 16, 2009, 07:56:25 PM »
This:
Blind Bearing Puller
Rent one at your local autoparts store.
mystic_1
Offline mick7504
« Reply #11 on: October 16, 2009, 11:25:42 PM »
Here is another "Non Honda Specialty Tool" for installation.
Home grown and works like a treat.
« Last Edit: April 23, 2018, 04:34:53 AM by Glenn Stauffer »
If I was you
Offline odin836
« Reply #12 on: October 17, 2009, 01:07:33 AM »
Mick, hows the home grown tool work?
Doesn't look like it will punch it down...
Doesn't look like it will pull either...
CB750 K3 in pieces.
Offline mick7504
« Reply #13 on: October 17, 2009, 02:01:03 AM »
This is used for installing the needle roller bearings.
It locates neatly inside and contacts the outer edge to eliminate the possibility of damage to the bearing during installation and also assists in guiding it straight.
I use a soft faced hammer to do this. (See Pics)
It has nylon heads which are replaceable and they are a good investment when working on these engines as they will not bruise the metal. (Covers,cases etc)
The brand name is "Thor" and are one of the better ones to buy.
Firm force is needed but not brutal force - There is a difference.
« Last Edit: November 02, 2009, 01:08:21 AM by mick7504 »
If I was you
Offline the-chauffeur
« Reply #14 on: September 30, 2010, 04:29:50 AM »
Guys, I have a correction/addition for you in relation to one of the bearing no's above - and it's an expensive one to get wrong (don't ask).
My K2 has a different final drive bearing to the one listed above - very different.  The bearing in question is labelled in the diagram above as 3206ATN9.  On my K2, the bearing I've just detached from the drive shaft is a 6305 - looks like the shaft size on my K2 is narrower than Mick's.  The key differences are the internal diameter and the bearing depth.
The 3206ATN9 has an internal diameter of 30mm and a depth of 23.8mm
The 6305 has an internal diameter of 25mm and a depth of 17mm
Oh, and the other big difference is the price.  The 3206 cost me about 6 times more than the 6305.
Hope that helps.
Offline mick7504
« Reply #15 on: September 30, 2010, 05:01:01 AM »
Hi mate
What you have there is an early model final drive with the single row bearing. (6305)
These bearings are a reasonably common run of the mill bearing that suit a variety of different applications (Automotive and Industrial)
Some info here on the Satanic Mechanic (Axl's) site.
http://www.satanicmechanic.org/gearbox.shtml
Thanks for sharing.
If I was you
« Reply #16 on: September 30, 2010, 05:32:21 AM »
Ah, that'll be why it's different.
Since the later bits are interchangeable, am I right in thinking it might be an idea to get hold of a later final drive for longevity/smoothness?  Looking at the bearings, the later ones are far more substantial than the earlier ones.
Any thoughts?
Offline mick7504
« Reply #17 on: September 30, 2010, 03:56:29 PM »
Any thoughts?
Definately for sure mate.
More balls are always better.  ;)
If I was you
Offline Gaither
  • '77 CB550F
« Reply #18 on: September 30, 2010, 06:44:18 PM »
Thanks, Mick (and others). LOTS of good info here!!!
PLEASE DO post this valuable info in FAQ.
FWIW, if you have a bearing in your hand, in MOST (but not all) cases, a comprehensive Industrial Bearing Supply House can come up with the same bearing (or a usable substitution).
A time or two (antique cars), I've had to buy bronze "Oilite" stock and have it machined to the orig bearing specs. Although in a lot of cases, this will NOT make a suitable substitution.
Great research and info here from you guys.
Thanks
Gaither ('77 CB550F)
  • Moderator
« Reply #19 on: October 22, 2010, 11:22:31 AM »
Edit: 6/2015---
One thing I'd like to add: the bearing #23 (thanks, Kickstart!) in this picture is an "Extra Clearance" bearing. While standard bearings will work, they will make the shifting of gears 3,4 & 5 stiff when the engine is hot or under power because of the twisting of the crankcases. The Extra Clearance bearings can be had from any bearing house: they are usually associated with very tight press-fitted holes, but here they serve a different purpose. The Extra Clearance is about 0.0004" in the races, to prevent bind and power loss (and extra heating).  :)
A local bearing house has told me that since 2008 or so, the "normal" bearing clearance has become, through general usage, the old C3 classification. It was, for many years, the C2 as "normal", now not so. This C3 class is also now known as the "electric motor bearing" class.
« Last Edit: April 23, 2018, 04:34:07 AM by Glenn Stauffer »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=8r2c7ckj1fuqmldr86tp7plbm5&/topic,60973.0.html
« Reply #20 on: October 23, 2010, 01:30:38 AM »
there are c kodes on bearings..ect 6205-c3..c-3 are with bigger"vider" tolerance then c-2
i hate all this v-w.... vords
Offline mick7504
« Reply #21 on: October 23, 2010, 02:53:48 AM »
Mark (Hondaman)
That's a good point about the internal clearances mate.  ;)
Terry
These a are quality bearings and there isn't one that has Chinese or Taiwanese origins.
Glad it helps mate.  :)
If I was you
« Reply #22 on: October 23, 2010, 02:58:46 AM »
Thanks Mick, I've used SKF bearings before with no issues, they were great.  ;)
  • Moderator
« Reply #23 on: October 24, 2010, 09:41:06 AM »
Me, too, but I had to take out a 2nd mortgage to get them.  :o
Offline wohali
  • What, me worry?
  • Don Pardo, tell 'em what they've won!
« Reply #24 on: March 28, 2011, 11:04:57 AM »
Hi folks,
Just ordered these bearings for my '78 F3 - thanks SO MUCH for putting this all together in one place!
For my Canadian friends, don't mess around with the motorcycle shops, who are going to overcharge you anyway, and possibly not get you good parts. Go straight to the source: Canadian Bearings. They're uber-friendly and will take your order right over the phone with a CC. They also have walk-up counters all over Canada.
For a full set of engine bearings, all SKF-made with two exceptions (see below), the price wasn't bad compared to marked-up poorly made Chinese bearings!
BearingPrice (CAD)
HK2520 Koyo12.18 ea (24.36)
3206ATN9/C3 SKF61.73
6003 SKF16.95
6008NR SKF47.75
6204 SKF9.80
6205 SKF10.55
6205NR/C4 NTN (*)17.55
6304 SKF13.00
6304NR SKF23.11
Subtotal224.80
The salesperson also stated that SKF doesn't make the metric needle bearings, so I went with her suggestion of Koyo ones instead.
Unfortunately, for the 6205NR/C3, there was no stock anywhere in Canada. They were able to locate an NTN /C4 clearance bearing locally, so I decided to go with that, versus no extra clearance and having the sticky 3-4-5 gear shifts Hondaman mentions above. The ranges of tolerance overlap anyway.
Canada Bearings assured me repeatedly that the NTN bearing would be of the same quality as the SKF bearing. :)
