Author Topic: Quick spark test question  (Read 1137 times)
Offline McQueen 750
  • Yeah, I'm finally a
  • Time to ride
« on: October 14, 2009, 01:26:15 AM »
If I have everything connected correctly (coils, ignition, etc), then kicking the engine over with a spark plug removed from a cylinder and touching the engine should result in a spark, right?
-1975 CB750F (Follow the thread: http://forums.sohc4.net/index.php?topic=88829.msg997640 )
-1978 CB750K8(Parts bike)
"Trust me you'll regret it, but you'll regret it more if you don't at least try it."
Offline Hush
Re: Quick spark test question
« Reply #1 on: October 14, 2009, 01:28:38 AM »
Yup, just remove one and lay it along the motor so it earths, no spark means you have missed something.
Offline Toxic
« Reply #2 on: October 14, 2009, 04:13:24 AM »
True, but using the kicker will make it harder to see the spark. Do it in the dark with a buddy keeping an eye on the plug gap.
Offline McQueen 750
  • Time to ride
« Reply #3 on: October 14, 2009, 09:55:57 AM »
Awesome. Also, do I need to have the battery, rectifier, etc. hooked up as well or can I start testing w/ just the ignition system hooked up?
« Last Edit: October 14, 2009, 10:07:45 AM by 750 Wes »
Offline kenolds
  • Before the Dismantle
« Reply #4 on: October 14, 2009, 12:03:56 PM »
The battery must be hooked up!  The alternator won't produce any current without the battery setting up the electrical field in the windings (unlike some other bikes and lawnmowers).  If some parts of the charging system are not hooked up just make sure the points and coils are getting 12V.  It should spark even if turned over slowly.
Kenolds
Parts, Parts, Everywhere - But Not A Bike To Ride.
Offline McQueen 750
  • Time to ride
« Reply #5 on: October 14, 2009, 12:09:32 PM »
Great, thanks guys!
