Have a stock 1973 CB750K3. It is difficult to start, even though it's in the 70's and 80's down here in Texas. Sometimes have to choke the carbs and then ride the throttle for a minute or two before it will idle on it's own without dying. Once it's idling steady on it's own, it's at about 950-1000rpm. This is not altogether that big of problem, however what is weird is that once I am riding the bike, the idle speed with slowly increase. Eventually, it idles at 2Krpm and slowly rises up to about 2.5/2.8Krpm on it's own. I manually reverse the throttle to keep the idle at about 2Krpm when I am sitting at a stop, but often when I am riding in the low range of a gear and I pull the clutch, it actually idles higher with the clutch engaged than when in gear. Does this bring any immediate thoughts to mind for anybody out there?
