Author Topic: No starter or kick, can I check compression by hand?  (Read 13971 times)
Offline daewon774
« on: October 15, 2009, 11:08:03 AM »
I have a CB650 missing some parts.  I'd like to check the compression on this engine (sold as a parts bike, now a project).
Tell me if I did this wrong, I first wanted to see if the engine turns over so I took a wrench to the rotor (behind the stator cover on the left side) and turned.  It turned over fine, but I'm not sure this is a proper way to test if the engine is turning over (aka not seized).
So, now that I 'think' the engine is turning over, I'd like to check compression.  Can I do the same thing, take a compression tester, throw it in, then turn the rotor a few times to get a reading?  Carb is off, so throttle doesn't have to be held open :)
76' CB550
11' Ducati 848 EVO
Offline Gordon
  • 750K1, 550K2
Re: No starter or kick, can I check compression by hand?
« Reply #1 on: October 15, 2009, 11:24:26 AM »
If the engine turns, then it's not seized, but I don't think you're going to be able to turn it fast enough by hand to get a good compression reading.
Offline daewon774
« Reply #2 on: October 15, 2009, 11:54:23 AM »
is it speed of the pistons turning thats important?  I thought I just want to make sure the pistons/seals/rings are compressing gas sufficiently in a given volume.  Does speed matter for this?
76' CB550
11' Ducati 848 EVO
Offline BVCB650
  • Too Much Thin Air
« Reply #3 on: October 15, 2009, 12:27:03 PM »
Put a 15/16" socket mounted on a 1/2 inch drive drill. Take the RIGHT side cover off, and have at it.
1979 CB650, 25K miles, recently refurbished
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
« Reply #4 on: October 15, 2009, 12:28:28 PM »
you will NOT be able to measure compression without a start device.  Try a leakdown test instead.  You don't need to use a start device.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline BVCB650
  • Too Much Thin Air
« Reply #5 on: October 15, 2009, 12:31:28 PM »
But that won't tell him what may be wrong, for example bad rings.
Offline 750goes
  • it will live
« Reply #6 on: October 15, 2009, 12:46:19 PM »
Yes it will
Offline BVCB650
  • Too Much Thin Air
« Reply #7 on: October 15, 2009, 01:46:59 PM »
Yes it will
No it won't!! It may tell if there is a leak or not, but not the source. Only way to do that is to circulate oil to the rings manually. Why guess the valves are leaking without verifying the valves or rings??? Or, it could be the cam lobes are worn, or the cam chain is worn or off a notch or two. Huh????
« Last Edit: October 15, 2009, 01:51:21 PM by BVCB650 »
« Reply #8 on: October 15, 2009, 03:44:55 PM »
Using a leakdown tester pressurizes the combustion chamber.  If the rings leak you hear it in the engine breather.  If an exhaust valve leaks, you hear the leak in the exhaust.  If the intake valve leaks you hear it in the intake.
With only a compression gauge you rely on perfect ring and valve seal get any reading at all (and none are perfect).  If they do leak (likely) then it is a ratio of how much is lost vs what was built up over time.  I can't think any meaningful info can be gleaned with this approach.
Doing a compression test by turning it over by hand will NOT tell you condition of rings or valves.  It might tell you if you have a holed piston, and broken/bent/ burned valve.  But, only expect to isolate catastrophic failures and you don't need any gauge for that.  Just put your finger over the spark plug hole and see if the compression stroke pushes it off the hole evenly for each cylinder.
Offline BVCB650
  • Too Much Thin Air
« Reply #9 on: October 16, 2009, 06:38:29 AM »
All true IF he is a competent mechanic, which apparently he is not. Took the wrong side cover off, and we don't know which way the engine was rotated. I don't understand why he doesn't hook up a good battery and turn the engine over with the starter.
Offline daewon774
« Reply #10 on: October 16, 2009, 06:46:28 AM »
Didn't get that information until now about the cover.  It's the reason why I came on here in the first place to ask you all.  I didn't know I was going to be flamed for asking questions.
I also don't have a stator on this bike or a R/R.  All parts missing when I bought this as a parts bike.
76' CB550
11' Ducati 848 EVO
Offline BVCB650
  • Too Much Thin Air
« Reply #11 on: October 16, 2009, 06:49:46 AM »
A missing stator doesn't have anything to do with being able to turn the engine over. In the future, more info would be nice, like what parts are missing etc. But to help you out, I did mention a way for you to turn the engine over in my first post. As always, it is wise to don thick skin.
Offline daewon774
« Reply #12 on: October 16, 2009, 07:03:33 AM »
You just asked why I didn't turn it over with a starter, and it's a 650 which doesn't have any type of kick start.  The topic title says I don't have a starter.  And to add to that, I don't have other parts.
All I was asking was how I can check compression by hand without the starter.  You gave me an answer, I appreciate it.  I'm going to try the 1/2 drive drill.  No need to get hostile when you don't read through the entire post.
76' CB550
11' Ducati 848 EVO
Offline BVCB650
  • Too Much Thin Air
« Reply #13 on: October 16, 2009, 07:12:34 AM »
I'm not hostile at all. I did not read the lack of a starter in your title. My bad. You may want to use an adjustable drill motor to get the rpms down though. Also, it may be helpful if you pulled the plugs out of the cylinders that you aren't testing so the engine will turn over easier.
« Reply #14 on: October 16, 2009, 07:14:36 AM »
PM me if you need some advice etc....I live in Ashland MA
Offline daewon774
« Reply #15 on: October 16, 2009, 07:23:16 AM »
cool thanks, I honestly didn't know that speed was a factor when checking compression.  For some reason I just thought if there was movement from the pistons that, if the seals were good, the compression would still show.  I'll update this weekend on the drill method.
76' CB550
11' Ducati 848 EVO
Offline the technological J
  • deliciouso!
« Reply #16 on: October 16, 2009, 07:27:32 AM »
easy guys i think we're a step away from name calling (seen it on other threads)..
but scwabling (skwable, scuable?) bickering aside
 you might find the downloading manuals handy thier at the top of the thread page from what i under stand if u determine u have low compresion and u put some oil in the cylinder and it raises u have a bad ring if not it may be a hole in the piston or a valve. if u have the time and are not in a rush to get the engine running pull the head... theres nothing like hands on experience with these old bikes
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline BVCB650
  • Too Much Thin Air
« Reply #17 on: October 16, 2009, 07:38:25 AM »
We're all good. I suggested oil on the rings if there is a low number in a cylinder or 2 to further diagnose the issue. A number of things can cause a lower reading, but in the end, it is what is acceptable to determine the health of the engine that is desireable. First things first.
Offline 74cb750
« Reply #18 on: October 16, 2009, 07:50:22 AM »
check your pm's, as I 'm driving down to Newton, Ma today to see my kid.
I'll bring a starter if you want.
peace,
michel
Laugh at least once a day.
Life  $ucks, then you die.
Offline razor02097
« Reply #19 on: October 16, 2009, 08:09:54 AM »
If you use a driver make sure its not an impact type.  Don't want to booger up threads or break bolts
Project Rina
