Author Topic: Magpie/Cliff's K0 Project  (Read 84087 times)
Offline Magpie
Re: Magpie/Cliff's K0 Project
« Reply #175 on: June 10, 2010, 03:48:51 PM »
Yes! Got a spare K0 swingarm gathering dust?  ;D
Cliff.
Offline Johnie
« Reply #176 on: June 10, 2010, 03:50:23 PM »
I hope it is an easy fix for you Cliff. For what it is worth, my KO center stand was bent when I got the bike. Turned out the PO had to bend it to make the 4-2 exhaust fit. Any chance the PO bent yours?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Magpie
« Reply #177 on: June 10, 2010, 04:03:49 PM »
There is a large flat spot on it from a crash I'll bet. I have another to compare it to but it's in rough shape too. Some of the bikes went through hell to get to us.
Cliff.
traveler
« Reply #178 on: June 10, 2010, 05:08:56 PM »
Cliff,
I cannot begin to tell you....how happy I am that the frame itself is O.K., especially seeing how the frame was already straightened on the front half.
Now....where in the hell do you find a K0 swingarm???  I didn't even know there was a difference!  What are the differences?
So....once one is sourced, you will need to get some bushings installed and then powdercoated.
disaster averted!  This makes my day!
P.S.  So....you are going to sell this bike to me when done.....right? :D
(seriously, I would buy it, if you were to sell it)
~Joe
Offline Magpie
« Reply #179 on: June 11, 2010, 12:47:41 PM »
Thanks Joe! Yes, happily, it seems the frame is ok. I'm still kind of perplexed by the comparison of the "bent" one and another one I have, K2+. They both measure and look the same. The K0/K1 swing arms have kind of a tab affair at the front of it that the plastic chain guard slips into. The later ones have a threaded higher tap that the metal chain guard is screwed to.  Details, details.
I think I'll have to put the "bent" one back in and see if all this just comes down to operator error. Boy will I be embarrassed if it is.  :-[
Cliff.
traveler
« Reply #180 on: June 11, 2010, 01:18:19 PM »
Cliff.
If the swingarm IS bent, perhaps IT can be straigtened out instead of digging for another one?
~Joe
Offline Zaipai
    • My Home page
« Reply #181 on: June 11, 2010, 07:32:46 PM »
Gratz man so glad to hear its fixable. Don't skimp on the details now.. keep going and if you need a new swing arm then keep looking there has to be one out there some place with your name on it..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Magpie
« Reply #182 on: June 12, 2010, 07:37:33 AM »
I'm thinking now it's more in the pivot bolt and collar area that may be out of line, skewing the swing arm off to the side. I'll do some measuring today. I had to drive the collar out of the swing arm and it had some scoring on it from lack of lubrication in the past. The collar in the other swing arm slides out easily. There's no visible damage to the front of the swingarm, maybe it's inside?
Cliff.
Offline Magpie
« Reply #183 on: July 06, 2010, 07:28:36 AM »
Just to keep my build thread up to date. I started another thread regarding the frame fiasco here http://forums.sohc4.net/index.php?topic=72213.0
So the next step is to take it to a local guy who has a cage to strap the frame into it to isolate the part that needs straightening. I've ordered a new rear fender but will use an old one to use to check that it's centred now. Then new tires. Should I go with my favorite, the Dunlop TT100's or tires that are more factory correct? like the Metzlers like these http://www.americanmototire.com/catalog/product_info.php?cPath=33_108_119&products_id=1383
Cliff.
Offline Johnie
« Reply #184 on: July 06, 2010, 09:12:33 AM »
Cliff...I have the Conti's on the KO, K1 & K4. My decision was based on info from guys on this board. Good tire. Here is a pic for you to help you decide. Click to enlarge...
Oshkosh, WI  USA
Offline Magpie
« Reply #185 on: July 06, 2010, 10:56:50 AM »
Those look great Johnie! Thanks. Where did you get them from and are they stock sizing?
Cliff.
Offline Johnie
« Reply #186 on: July 06, 2010, 11:25:07 AM »
I got them from my dealer as he gives me a discount on my stuff. They are stock size called Continental K112's. Be sure to get new tubes too. My rear was K112 - 400H18A cost was $132. The front was the RB2 325H19 and cost was $100. Then they give me a discount for mounting too. You may be able to find them other than your dealer at a cheaper cost, but my dealer treats me pretty good so I want to do business with him.
Oshkosh, WI  USA
Offline Magpie
« Reply #187 on: July 06, 2010, 12:54:54 PM »
Thanks Johnie!
More interesting findings. I wanted to see how the seat pan will sit on the frame before I get it recovered/redone and low and behold it sits off centre, much to the left. The tank is centred over the frame rails as you can se from the pics below but the seat is way off. It's off to the frame pros for sure now. It looks like the entire rear section has been moved over a bunch. I don't remember picking up on this when I took it apart. I did have the steering head straightened but could this be from that process? There's no signs of damage to the frame rails anywhere.
This is getting disheartening.
Eric, do you still have that K0 frame, is it a **/69?
Cliff.
Offline Johnie
« Reply #188 on: July 06, 2010, 01:00:14 PM »
Man, that frame issue is sure depressing Cliff. I feel for ya". Hard to believe it could be that far off. You have been putting heart and soul into this project. Continue on and it will be remedied. Good luck with it...
Oshkosh, WI  USA
Offline Magpie
« Reply #189 on: July 06, 2010, 02:11:41 PM »
Thanks Johnie! Words of encouragement are more than welcome at this point!
Cliff.
Offline Johnie
« Reply #190 on: July 06, 2010, 02:45:06 PM »
Keep in mind it took me over a year to get my KO tank remedied with the pin holes. I thought it would never end. 2 fixes and 3 paint jobs later it finally is sorted. Keep your focus on the completed project and that should help get you through this part.
Oshkosh, WI  USA
Offline Magpie
« Reply #191 on: July 06, 2010, 07:37:41 PM »
"I thought it would never end" Amen brother!
I have this above one of my workbenches to keep me in focus but I forget sometimes...................
Cliff.
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #192 on: July 07, 2010, 05:58:31 PM »
Cliff.
That's great. I have nearly the same inspirational pictures up for my CB450 project right now.
It helps me after I botch up a job or hit the wall.
Baby steps, baby steps...  :)
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Magpie
« Reply #193 on: July 09, 2010, 09:41:59 AM »
Next baby step.
I covered it up and walked away for a bit and feel refreshed so time to check the wheel alignment front to back to see if things line up. I borrowed 2 long pieces of angle iron from a friend, set them up on 4 x 4's front and rear, laid the rails tight to each side of the rear tire and measured the distance from the rail to the front and rear of the front rim. I shot a picture of the measurements. As you can see it appears to be in line or very close to it. This is not going to a racer so I hope it's good for street riding. The difference from side to side is very small, if I'm reading this right. I'll have a friend that told me how to do this come by to double check. Any pointers to help further?
Further, I laid a straight edge against the inside of the drive sprocket and the primary sprocket and they line up.
So, hopefully it's just to pull the top rear of the frame to the right a bit and carry on.
Thanks,
Cliff.
Offline Magpie
« Reply #194 on: July 09, 2010, 09:45:59 AM »
And, further to the seat pan not lining up, "upon further review" the seat pan mounts are bent all to hell, the ones that bolt to the seat pan. I compared them to my K1's which line up nicely just to check. I'll pull some mounts off an old seat, put them on the K0 pan and see what happens. I'll do this after my friend drops by to check my work in the post above. Another baby step forward.
Cliff.
Offline hoodellyhoo
  • CB350F
« Reply #195 on: July 09, 2010, 03:57:11 PM »
Nothing wrong with baby steps. Glad to see that you've got those problems figured out.
Offline Zaipai
    • My Home page
« Reply #196 on: July 10, 2010, 07:50:37 AM »
Yeah, have to crawl before you can run..  ;D
.: Scott :.
Its my Avatar..
75 CB550F  |
traveler
« Reply #197 on: July 10, 2010, 07:58:46 AM »
needle nose pliers can straighten that!
Offline Magpie
« Reply #198 on: July 10, 2010, 08:24:50 AM »
Done, they came back to normal quite easily. The question is how did they get that way without major trauma to the area around them? I'm beginning to think this bike has a very colourful past. It's also showing me how much I still have to learn about these wonderful bikes.
Cliff.
Offline Zaipai
    • My Home page
« Reply #199 on: July 11, 2010, 06:57:17 AM »
Cliff.
I believe you are correct.. It would be so great if we only knew the entire past of these old beauties!
Oh wait, I guess these forums are one way to document it. However it would be nice to know all the past tho.
.: Scott :.
Its my Avatar..
75 CB550F  |
