Author Topic: Magpie/Cliff's K0 Project  (Read 82802 times)
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
Re: Magpie/Cliff's K0 Project
« Reply #250 on: April 22, 2011, 05:28:28 pm »
Great work Cliff, Nice documentation as well. I can't wait to see the final. Keep it up man!
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline Prospect
« Reply #251 on: April 23, 2011, 05:33:39 am »
Engine Paint looks great Cliff.  Did you use VHT paint?  Any plans to cure it in the oven?
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Magpie
« Reply #252 on: April 23, 2011, 08:05:32 am »
The paint is Duplicolor 1615 Aluminium engine paint. I haven't talk to the wife about using the oven but i suspect a quick short answer would come back. I left the cases out in the sun for quite awhile and as a friend pointed out, when the engine is running it will cure the paint. I didn't think of that.
Cliff.
Offline markb
  • When I finish my current project I might be a
« Reply #253 on: April 23, 2011, 09:09:01 am »
I wouldn't put them in the oven, at least not too hot.  I just pulled a head that I dropped off for some valve work.  It was painted with the same paint.  They heated it to 350 degrees F. to replace the exhaust valve guides and it turned the paint to a golden color.  That's way hotter that the engine will ever see so I'm not too worried.  They bead blasted it and I'm going to repaint with the same paint.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Magpie
« Reply #254 on: April 23, 2011, 11:52:23 pm »
Got the cylinders and head painted today and "lettered" the K1 switch for the other bike.
Cliff
Offline Magpie
« Reply #255 on: May 08, 2011, 07:51:49 am »
A step forward and a step backward. Assembled all the parts in the upper and lower cases, smeared Hondabond on the machined surfaces (the Hondabond is runny but the tube is about 5+ years old), mated the them, installed all the bolts, installed the shifter assembly and.........................it won't shift. The shifter fork must be jammed. Take it all apart, but leave the shifter assembly on the lower case and sure enough the shifter fork is stuck. The cases did mate cleanly though. Get that fixed but now I have to remove the dried on Hondabond which means taking everything out of the cases to be sure there's no bits of the bond staying/hiding in the cases. And I think I should get some new bond. The jammed fork may have saved me from grief later as the Hondabond seems to have dried hard and not semi dry as the tube says.
My buddy "Do It Again Cliff" has come back. The cases did look good bolted together though.
Cliff.
Offline cooch
« Reply #256 on: May 22, 2011, 12:20:50 am »
Cliff! Kenn here, You're right, I'm infected now looking at all the projects, I think I need to go deeper down the rabbit hole. see you May 29th
1973 750
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #257 on: May 22, 2011, 07:35:57 am »
Good piece of mind, especially if you’ve found hard bits loitering.
Offline Magpie
« Reply #258 on: May 22, 2011, 09:36:57 am »
Kenn, the rabbit hole has no bottom, it's a great place though!
FunJimmy, yes I feel better about it now. The local shop recommended Permatex Ultra Grey  RTV Gasket Maker (No. 82194) instead of the HondaBond. It's half the price and goes on nicely. I used my finger to smear on a nice light spread of it taking care to wipe off any excess on the inside of the case. It stays wet for a longer time and is nice to work with. I got the two halves joined and made sure the shifter works. I took more care in making sure the shifter fork went where it was supposed to, maybe too much of a rush last time. It shifts through the gears nicley and there's just a tiny bit of sealer showing at the case joint so it should be good.
Cliff.
Offline CB750faces.com (Lecram)
  • CB750faces.com
    • Buy High Quality Honda gauge parts online!
« Reply #259 on: May 23, 2011, 02:00:17 am »
Great job.
I suggest to check also if all the gears work well before you put your engine in the frame. I made a huge mistake by mounting the fifth gear in the wrong direction, what resulted in an idle tuning fifth gear. Now I have to take the engine out of the frame, open the cases again to turn on the gear wheel. That's a tough job with a fresh painted frame...
Offline Magpie
« Reply #260 on: June 11, 2011, 02:18:55 pm »
Hi! It seems to run through the gears nicely on the bench, thanks for the tip!
 No progress lately, cash calls for other stuff happening rapidly. Cliff.
Offline Magpie
« Reply #261 on: August 08, 2011, 01:51:18 pm »
Some progress-just ordered 4 sets of .25 over piston rings, 4 piston pins, 8 piston pin clips and 4 exhaust gaskets. Now I can reassemble the K0 motor. ;D at last. Ordered from these guys, the prices seem good. http://www.vintagecb750.com/
Cliff.
Offline Prospect
« Reply #262 on: August 12, 2011, 06:53:47 pm »
Cliff.
I've ordered from these guys counteless times.  Good service and quick delivery. They did send me the wrong ignition once after I confirmed the one I needed.  I have to send it back.  A lot of their stuff is reproduced in Taiwan though.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline Magpie
« Reply #263 on: August 15, 2011, 11:57:51 am »
Thanks, I wasn't sure about them but another SOHC4 friend has and felt it was good product. The order hasn't arrived yet. I did buy a set of K0 carbs for the sandcast motor from a forum member so the sc will make a nice display engine in my man cave until a frame comes along that I can afford.
Cliff.
Offline Magpie
« Reply #264 on: August 16, 2011, 01:09:48 am »
It's 1:05 am and I've just managed to strip the threads out of one of the cam carrier bolt holes. Dammit! Time for bed. Got the new piston rings on, installed the cylinders and the head, almost done and ................ bolt went in a little ways and just snapped. Took it apart, removed the broken off piece and used a new bolt, then it wouldn't tighten. Ratz!
Cheers, Cliff.
« Last Edit: August 16, 2011, 07:25:33 am by Magpie »
Offline Magpie
« Reply #265 on: August 16, 2011, 10:34:19 pm »
Better day today. My friend Rick came by and we - he- did a helicoil for me and it's all good. Reassembled the top end, set the valve clearance, installed the starter motor and put it away for the night. Next is to have the engine cases polished by the end of the month. Then take the sandcast motor out of the K0 frame and put the right motor back in.
Offline Johnie
« Reply #266 on: August 17, 2011, 06:50:36 am »
Sure lookin' PURDY there Cliffy...I am talking about the motor... ;D
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Magpie
« Reply #267 on: August 17, 2011, 08:18:02 am »
Thanks Johnie! Rick will be glad it's the motor and not him that's PURDY! I'm going to have to learn how to do Helicoils for myself soon I think.
I bought a set of K0 carbs from a forum member for the sandcast motor. It will look good on a stand with a spotlight shining on it. My first piece of modern art.
Cliff.
« Last Edit: August 18, 2011, 05:59:41 pm by Magpie »
Offline Magpie
« Reply #268 on: August 18, 2011, 08:52:59 pm »
Worked on an incomplete set of K0 carbs today. Stripped down, black paint removed and cleaned up. There's another thread about clean engines saying his carbs were soda blasted and they look great. I'm going to have to find someone here to do that.
Cliff.
Offline lucky
« Reply #269 on: August 18, 2011, 11:01:49 pm »
I would have waited and turned the engine on its side, and then lifted the frame over it.
Putting the engine in after the frame is all assembled seems more difficult.
Offline Magpie
« Reply #270 on: August 19, 2011, 08:14:23 am »
You're right. I'll have to take some stuff off to make the frame lighter. I have a couple of volunteers that will help lift and lower-young guys with strong backs. When the die cast motor is completely ready to go I'll get the bike ready for a quick motor change.
When I got the sand cast motor I thought it would be great to be able to show it in the bike but have decided that the correct motor (the one it came with) should be in the frame. The sand cast motor can wait for another opportunity. It's rebuilt and runs fine so it will be ready for action when the time comes. Meanwhile it will also look great on the bench.
Cliff.
Offline Magpie
« Reply #271 on: August 25, 2011, 08:03:48 am »
Been busy cleaning and polishing since it's just time consuming and good mindless work to enjoy. I purchased a second set of K0 carbs fom a forum member (thanks John) and waiting for a set of carb springs and tops that I found on eBay. A friend of mine has a small sand blaster he'll lend me (see shiny carbs thread) so I'll try soda blasting the carb bodies if my small compressor is up to it. Also installed a set of covers of the K0 engine just to protect it. The covers need polishing too which should happen next month. My business is slow right now so progress is slowing down a bit. If I stopped buying extra stuff I would probably be much further ahead but it's hard for me to pass up a good find.
By the way, the plastic boxes are from the fishing department at Walmart at $5 or so each. A great way to organize things.
Cliff.
Offline Magpie
« Reply #272 on: August 26, 2011, 01:24:13 pm »
Got one set cleaned. Cliff.
Offline gonzobrian
« Reply #273 on: August 28, 2011, 05:02:27 pm »
The carbs turned out looking good.  You don't happen to know of a source for the brass stop nuts on the top?  I'm missing two of the little buggers.
Offline Magpie
« Reply #274 on: August 28, 2011, 07:17:44 pm »
Thanks. Sorry I don't know who may have those, I'm surprised Yamiya doesn't. Cliff.
