Author Topic: Magpie/Cliff's K0 Project  (Read 83631 times)
Offline Prospect
Re: Magpie/Cliff's K0 Project
« Reply #375 on: March 23, 2013, 01:42:33 PM »
Looks like with those you'll have to worry about correct placement for the emblem holes.  The ones I got from Frankenstuff had dimples in the correct spots for drilling.  Franky's are priced better, but I'm not trying to pressure you either way, just offering info.
I'm saving my pennies up for the LPM air box now..it is a nice reproduction.
Looks like you're right. I don't know the correct placement of the emblems and wouldn't trust myself to eyeballit. It doesn't take much beong off to notice the probelm. I think this is enough for me not to get them but I'll get their airbox.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Magpie
« Reply #376 on: March 23, 2013, 01:58:43 PM »
Frank's look better to me all the time. Thanks guys, Cliff.
Offline Magpie
« Reply #377 on: March 23, 2013, 02:55:49 PM »
He may not be making K0 ones anymore according to his web site. I posted on his thread asking about them. Cliff.
Offline Magpie
« Reply #378 on: March 23, 2013, 05:25:46 PM »
Update - Franky will make me a set when he can, possibly next week, I'm in no rush right now. He got back to me very quickly which is great. Cliff.
Offline Prospect
« Reply #379 on: March 23, 2013, 07:01:03 PM »
Very good. I'll get a set.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline Magpie
« Reply #380 on: March 25, 2013, 09:34:59 PM »
My gas tank repair continued from my Help, I f&^%$%$# up my tank.
To recap, I used an impact driver to try to remove the screws holding the fuel tap to the tank resulting in pushing the tap mount down and making a mess of it. Panic stations. Walk away. Post a "HELP" thread and back come the answers, "it's a simple repair, really". Pull the sunken part back up using a metal plate and 2 bolts.
Here's the damage.
So, a friend has the perfect piece of scrap metal, already drilled with holes that line up perfectly! 2 bolts and I'm away. Gently tighten then up to the point where I'm afraid I'm going to pull the threads out of the tank. As per Frank's suggestion I put a piece of cardboard between the tank and the plate.
Which pull's it up quite a bit.
And the tap fits quite nicely, it has a fairly deep o-ring on the mount.
Now to make it smooth. I filled the deep divot with JB weld including a smear across the whole area, cleaning the threads with a Q-Tip. When this sets I will block sand it back to bare metal and the divots will be level with the mount. Being level and having the o-ring, it should be fine and not leak. Filling the tank with water should be a good test.
I wonder if I should be using smaller pictures?
Cliff.
« Last Edit: March 26, 2013, 07:23:20 AM by Magpie »
« Reply #381 on: March 25, 2013, 10:10:51 PM »
Glad your tank mod is coming along nicely. (;D)  That got your heart rate up, I'm sure.
Look forward to future photos and progress.
David
Offline Magpie
« Reply #382 on: March 26, 2013, 07:26:46 AM »
Thanks David! It's interesting that many things I post that I seem to think are going to be hard to repair, a forum member will post a reply saying "that's not so hard to fix, just do this.................". What a great place!
Cliff.
Offline Magpie
« Reply #383 on: March 26, 2013, 07:33:08 AM »
Geez, I just noticed, it almost 3 1/2 years into this bike and it's coming down to just paint and pipes. I have a crappy set on it now but if need be I can rob a set off the K1's to qualify for my Collector license plate and cheaper insurance. Doesn't seem that long ago that I got this bike but I have a picture of it shortly after it arrived dated March 19, 2007! Amazing - glaciers have moved faster than me - ha! Cliff
Offline Magpie
« Reply #384 on: March 26, 2013, 11:43:48 AM »
So, here's the results. I've filled the tank with water. It's not leaking, so far, around the join between the tank and the tap. It is leaking from the inlet to the float bowl which means I need a new packing for the tap. I'll leave the water in for a day and see what happens. If that's good I'll dump a couple gallons of gas in and see if the JB is effected by it and starts to weep.
After block sanding for a flat surface. Not much JB where the o-ring sits.
Where the worst of it was.
Leaky tap, will order a new packing.
Cliff.
Offline Magpie
« Reply #385 on: March 27, 2013, 11:36:09 PM »
Time to clean the inside of the tank with the vinegar treatment.
Offline danfr
    • Apollo Motorcycles
« Reply #386 on: March 28, 2013, 12:48:25 AM »
Oh geeze! The vinegar trick eh? Love it. Nice work filling and filing!
I'll be around this weekend if you would like that headlight piece.
-Dan
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline Magpie
« Reply #387 on: March 28, 2013, 06:06:43 AM »
Sure, let me know when would be a good time to drop by. Thanks, Cliff.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #388 on: March 28, 2013, 07:12:33 AM »
Nice job on the tank repairs Cliff.
Excellent documentation too.
Offline Magpie
« Reply #389 on: March 28, 2013, 07:48:44 AM »
Thanks! See you in Tsawwassen next month. Cliff.
Offline Magpie
« Reply #390 on: March 28, 2013, 08:14:19 AM »
Well I'm sold on the vinegar treatment now, this is just about a 12 hour soak so far. The rust is heavier in the bottom of course but this is very encouraging. Twilight Zone ? The level of the liquid in the tank is increasing slightly. Cliff.
Offline Magpie
« Reply #391 on: April 03, 2013, 10:02:44 PM »
I think the tank came out quite nice inside. I rinsed the hell out it then flushed with soda. There was bit of flash rust so I coated it with 2 stroke oil. Cliff.
« Reply #392 on: April 03, 2013, 10:49:39 PM »
Congrats on the tank renewal...what is next?
Offline Magpie
« Reply #393 on: April 03, 2013, 11:00:58 PM »
Waiting for new repro side covers from The Honorable Mr. FrakenFrankenstuff then take everything to my painter for a price. I have the tank decals already. But have to save a bit more $$'s too.
Meanwhile still puttering on the 750F and bought a book on auto body repair to learn how to repair the baby Benley.
Cliff.
Offline danfr
« Reply #394 on: September 18, 2013, 10:22:35 AM »
(cough cough)
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline Prospect
« Reply #395 on: September 18, 2013, 01:55:23 PM »
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline Magpie
« Reply #396 on: September 19, 2013, 07:52:23 AM »
Hi guys! Everything seems to be in a holding pattern for now. I'll get the urge soon. Cliff.
Offline Magpie
« Reply #397 on: January 29, 2015, 10:48:40 AM »
Working my way out of the holding pattern, life has been "interesting" the last while. Changed the carbs out for some that were brighter in colour. The others had been painted black and I guess the paint stained the metal. Also changed out the kill switch for a correct one. the one I had used was from a very early sandcast, black knob, no pointer. That will go into the parts supply for later project. Still have 2 Benlys and a 90cc Cub waiting for love.
The quality of the builds being posted is amazing. I need to up my game!
Cheers, Cliff.
Offline Old Scrambler
« Reply #398 on: January 30, 2015, 08:48:53 AM »
Good to see the progress ;)
I have one of 4 project's stuck on my bench for 4 years :(..........but finished 3 others since :D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #399 on: February 03, 2015, 10:05:40 PM »
Cliff, The Benlys...you talking CA95s... Are you using aftermarket gasket sets?  The dealer is telling me the Honda gasket sets are not available anymore. Supposedly the aftermarket set is complete but it really doesn't look like it is all there. It is hard to see what is there in the Head set that are listed.
I don't know what my CA95 needs or doesn't need. I know it does need a new paint job, something fierce. Sitting in storage since spring of 2009 in NE Tennessee's humid weather has not been kind to it. Sitting in storage in Arizona it would have been in much nicer shape. But, it had Iowa title and apparently was a storage unit sale because I bought it in 2007 as a project bike for $350. It was in pretty rough condition. Tires pretty rotten and fender dented up  and  multiple dents and dings along with a rusty right muffler that had shed his chrome entirely.
I bought the bottom end Honda Gasket Set B from a Indonesian seller who had it listed as a full gasket set, I educated him as the Gasket Set A being Top End and B being the Bottom End. Told him he could verify the part number with Honda parts department microfishe.
It could be a fake...never know these days. Hopefully not.
What did you use for gaskets on your CA95 build previously?
Nice progress on the bike... Keep it going.
David
