Author Topic: frame cut, what can i do?  (Read 1716 times)
jscro73
« on: October 16, 2009, 08:49:35 AM »
i bought a 71 cb750, and it looks like the previous owner cut the frame so he could take the head off with out pulling the motor out. While i think that this would be a great accomplishment on these old hondas, this guy went about it with no tact, and cut it up. there's a 6-8" piece missing from both of the smaller frame tubes that run from mid bike to steering tube.
what can i do about this? is there any way to repair it? or should i just scrap the frame? I wanted to make a custom bike out of it. i still have the motor and other parts. your thoughts would be greatly appreciated.
you can partially see what i'm talking about here. (http://jasonscroggins.wordpress.com/2009/10/15/photos-from-the-garage/around-the-garage-023/) If you look at the bike leaning to the left, you'll see the tube and where it stops.
thanks,
jason
Re: frame cut, what can i do?
« Reply #1 on: October 16, 2009, 08:56:28 AM »
Can be easily fixed. or a kit put in, to be a removeable section..
 Many have ridden them the way yours is, not good for roadracing though..
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: October 16, 2009, 09:00:19 AM »
You can do what others have done, and do this:
http://forums.sohc4.net/index.php?topic=20260.0
Gordon (Ilbikes) doesn't make the kits any more but someone should be able to whip these up for you pretty easily.
A skilled weldor could have new tubing back in there in an hour, but a kit like above still lets you work on the head without unshipping the motor.
mystic_1
- John Augustus Shedd
« Reply #3 on: October 16, 2009, 09:10:47 AM »
thanks,
jason
This was a fairly commoon modification for the purpose you surmise. Mine is that way. I have a frame tube removal kit. I did roadarace mine with this kit and no problems. Many threads on this in the forum.
« Reply #4 on: October 16, 2009, 09:45:53 AM »
I just put a kit like in the picture in mine, I've had it for a while. It's tack welded now and I will finish it this winter. APE used to make a kit with tubing that sliped over the frame tubes and bolted on, this would be lighter but maybe not as strong. Disturbing but not a 4 alarm emergency. Many drag bikes were like that in the seventies.
