Author Topic: Bike stumbles at idle to 1/4 throttle  (Read 27124 times)
Offline brett_bike
  • '73 CB500 Four K2
Re: Bike stumbles at idle to 1/4 throttle
« Reply #50 on: November 06, 2009, 06:49:22 PM »
I need to get new plugs for a proper plug chop.  I could only wipe off prior deposits, they still seem to be lightly black and dusty
Offline Spanner 1
« Reply #51 on: November 07, 2009, 08:01:52 AM »
Brett, do you think the advancer may have been stuck/sticky when you took it apart ? If so, you may have timed the bike ( before lube the adv'er ) with the cam turned partways towards full advance....i.e., might need to re-time or check with a timing light would be best.....
Offline brett_bike
  • '73 CB500 Four K2
« Reply #52 on: November 07, 2009, 07:36:47 PM »
Possibly, I hit it with the timing light this afternoon.  I'm at a stand still because I can't move my points plate any further to get the timing spot on.
Offline Spanner 1
« Reply #53 on: November 07, 2009, 08:05:26 PM »
That's a common problem with non-Honda points....Hondaman talks about it on a post...only solution is to file the three slots out to get the timing to advance/retard to match the 'F' mark.......or order Honda points.
« Reply #54 on: November 07, 2009, 11:47:58 PM »
