Author Topic: Gear driven primary on a 750?  (Read 9836 times)
Offline lordmoonpie
    • Moonpie
« on: October 20, 2009, 02:11:02 am »
There's lots of debate and theory and even a bit of practice around primary drive chains for racing and high speed riding on the 750 using the original dual chains but uprating them, changing to a 750A crank and a GL1000 cush drive with hy-vo chain etc.
While I was packing up a load of old bike magazines to send off to the troops in Afghanistan I ended up flicking through a few of them and there was mention of converting a 750 to a gear driven primary drive, I suppose something like on the 350 K4 twins. It would obviously solve the chain drive problems for a tuned engine but how much work would it be and would it even be possible?
Any engine gurus want to cast in their thoughts....?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline mec
Re: Gear driven primary on a 750?
« Reply #1 on: October 20, 2009, 02:57:20 am »
my thoughts:
my 1000ccm engine with stock 2 roller chains delivering 113 rear wheel HP runs flawless (under racing conditions) this year doing 13 or more practice sessions. this was not what i was exspecting, but what i was hoping. one time in my 140hp 4valve dohc 1130ccm bol d´or i broke a brand new hi-vo chain. therefore i fear that my 1000ccm engine will brake the two roller chains as well........but nope; till now.
if you are running an engine with similar or even less power there is no need for another primary drive (exept for noise reduction).
is the conversion doable?
everything is doable, but: you need a new crankshaft with incorporated primary gear (expensive and doable). to have the proper rotating direction you have to add another "secondary primary shaft" with bearings. where are these bearings located in the cases? are the cases stiff enough in this area? you would have to "redesign" the cases in some way. this "improvement" adds considerable weight to a heavy engine and increases inner friction of the rotating gears.
better way is to relocate the complete transmission an to go without the sprocket shaft........new cases anyway.
interesting technical challenge, but no good cost/performance ratio.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline voxonda
« Reply #2 on: October 20, 2009, 03:11:14 am »
Look at the first RCB endurance racers, they had what we want(?). Necessary? No, absolutely not. Nice to have? Yes, :) :) Imho the stories about the primary chain are getting out of hand the longer the saga goes. I am with Mec, everything is doable, at a cost. But if his 'monster' can't destroy the chains what will. I go for the reinforced once, because I have to replace. The oem set that I have will be used in another engine.
Rob
« Reply #3 on: October 20, 2009, 05:04:32 am »
Just run a set of the heavy duty primary chains Nippon/Ricky Racer are selling. They have quite a few sets that I'm sure they would be willing to sell to folks on the board.
Offline bert96
  • past ride
« Reply #4 on: October 20, 2009, 01:15:05 pm »
Is it really more quiet with these chains?
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Ricky_Racer
« Reply #5 on: October 20, 2009, 02:11:28 pm »
Since you asked... Bert, since the CCC Superduty Primary Chains have shown approximately 20% of the stretch of OEM primary chains at a field tested 60,000 miles, yes, they will be quieter. But perhaps the most important thing about them is that they will save costs by eliminating the need for repeatedly splitting the case multiple times a season for the repeated replacement of OEM primary chains.  And, of course, their increased strength will hopefully reduce DNF's due to failure of the OEM primary chains when used under extreme conditions.  RR
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: October 20, 2009, 04:58:16 pm »
RR,I need a set for 1000cc build.PM please,Thanks,Bill
BentON Racing Website
BentON Racing Facebook
Offline JLeather
« Reply #7 on: October 20, 2009, 05:32:21 pm »
Ted, we'll see what those chains can take.  I'm putting a set in my turbo motor.  Now, I won't be downshifting at 11k like mec, but I'll be hammering it at the strip once in a while.  I expect something else to fail first, having seen and heard what these chains can do.
  • Moderator
« Reply #8 on: October 20, 2009, 05:41:25 pm »
Ya need a nice auto trans to take out the snatch ;D ;D ;D Have you still binned the auto idea?
Sam. ;)
Offline Ricky_Racer
« Reply #9 on: October 20, 2009, 07:27:24 pm »
PM sent as per your request. Thanks, Bill!  RR
Offline nippon
    • Classic Cycle City
« Reply #10 on: October 20, 2009, 11:17:36 pm »
Hi,
a new 15 pages chain catalog is ready to download.
http://www.classiccyclecity.com/gallery/displayimage.php?album=48&pos=13
A short description:
With brand new stock RK primary chains, the lower crank case to chain tensioner
sag is 65.00 mm. In a stock engine (around 50 hp
at the rear wheel), stretch after 2-3 races results in 67.00-68.00 mm
sag. In a tuned race SOHC engine (100 hp at the rear wheel), we
measured a 71.00 mm! sag after three races.
Replacement of the primary chains is highly recommended by Honda at
70.00 mm sag in order to avoid engine damages. Since our test results
confirm a rather short life for the stock primary chains.
With our brand new heavy duty primary chains, the lower crankcase
to chain tensioner sag is 63.70 mm, so our high performance primary
chains stretched only 1.30 mm to 65.00 sag after three races in
a 91.2 hp SOHC engine, we did not reach the sag limit. Neither did we,
in road tests of over 60.000 miles with stock engines, reach the specified
sag limit. We highly recommend the use of our chains in stock engines,
too. The limited stretch of the chain will reduce the primary chain rattle.
nippon
« Last Edit: October 21, 2009, 12:22:52 am by nippon »
« Reply #11 on: October 21, 2009, 04:44:15 am »
Hi,
nippon
You really have to see these chains in person and compare them to OEM to appreciate them. Well thought out and well executed.
Offline simon#42
  • liverpool
« Reply #12 on: October 21, 2009, 09:49:55 am »
hi rr i would like a set of there as well , could you p.m. with price please
Offline Ricky_Racer
« Reply #13 on: October 21, 2009, 11:55:43 am »
Thanks, Simon. PM sent. RR
Offline JLeather
« Reply #14 on: October 21, 2009, 12:06:11 pm »
Sam, the auto idea got binned when I opened up the bottom end and found it was trashed.  After pricing clutch packs and other 'matic parts I decided they're just too expensive to rebuild, and I don't like the idea of putting this much money into an engine that I can't rebuild if I break it.
Offline simon#42
  • liverpool
« Reply #15 on: October 22, 2009, 10:09:57 am »
thanks ted , as you said it looks like a must have mod !
Offline kos
    • m3racing.com
« Reply #16 on: October 22, 2009, 12:17:18 pm »
Those new HD chains are on e-bay right now $395.00 buy now price.
KOS
220...221, whatever it takes.
Offline kos
    • m3racing.com
« Reply #17 on: October 26, 2009, 08:49:03 pm »
Yes, as someone said early on on this thread....anything can be done, if you want it bad enough.  Try this on for size. The only part that will be hard is the gear that you must put on the crank to drive the driven sprocket/gear on the mainshaft of tranny.
 We'll, let s start making new cranks. I'll get right on it.
How many does anyone want?
KOS
  • Moderator
« Reply #18 on: October 26, 2009, 09:05:41 pm »
and at only $15,000.00 that's gotta be a good buy. :D :D :D :D :D
Sam. ;)
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #19 on: October 29, 2009, 01:06:12 pm »
somewhere i actually have a pic of the factory gear driven primary on the early race cb750 bikes....see if i can find it
MATT
Offline KRONUS0100
« Reply #20 on: October 29, 2009, 01:08:14 pm »
ok i found it...holding it up for you all to see.....how do i get it on my computer and posted here?  i believe i still have a photobucket account.............
MATT
Offline KRONUS0100
« Reply #21 on: October 29, 2009, 01:38:26 pm »
ok....not sure how to...this image is at image shack under mbrizfam590.....anyone care to try and upload it here go ahead.
MATT
  • Moderator
« Reply #22 on: October 29, 2009, 02:48:56 pm »
Where are all the IT boffins when you need them. ;D ;D ;D
Sam. ;)
Offline voxonda
« Reply #23 on: October 29, 2009, 02:56:34 pm »
Think you mean this one:
It's the first 1976 RCB with the engine strongly resembles our engine.
Rob
Offline nippon
« Reply #24 on: October 29, 2009, 04:36:47 pm »
I guess it was done by Eckert, right?
