Author Topic: help with a 89 civic  (Read 1567 times)
rusky
« on: October 21, 2009, 04:57:13 AM »
Since this is an open forums. I have an 89 civic, and all of a sudden the car dont start. I checked the sparks. I am not getting any spark in any spark plug. I checked the distributor, it looks fairly new. So i dont want to spend 100 bucks on it yet. Any one have any ideas what else to check. Thanks
Offline ColinMc
  • There aint no pickle like a super pickle...
Re: help with a 89 civic
« Reply #1 on: October 21, 2009, 05:27:27 AM »
is it turning over? is it barely turning over...has it been sitting a while?
bad coil? just to randomly guess lol...
pop the cap off and check for corrosion?
idk need some more info about it...
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
jsaab2748
« Reply #2 on: October 21, 2009, 05:49:54 AM »
Does the distributor rotor turn when the engine is cranked? Make sure it does. If not, then niether is the camshaft, indicating a broken or stripped timing belt.
rusky
« Reply #3 on: October 21, 2009, 05:56:50 AM »
sorry forgot to add, it turns over fine. I drove it the night before it decided not to start. I checked the distributor cap for corrosion, almost none. The timing belt is good, i took off the valve cover and made sure. I was thinking some fuse or something simple.
Offline Alan F.
« Reply #4 on: October 21, 2009, 06:28:31 AM »
I say check the coil wire to the distributor, verify the coil is getting power too, then try a different coil if you can.  But remember parts stores don't accept returns on electrical parts...maybe you know someone with a similar car you can borrow a coil from for testing? Maybe an inexpensive coil from a junkyard?
And if you've been cranking it trying to start it be aware that you just may get a backfire out the exhaust when you DO get spark to the plugs, some fuel has probably made it into your pipes during the cranking...BOOM!
-Alan
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: October 21, 2009, 06:47:05 AM »
Bad coil.
rusky
« Reply #6 on: October 21, 2009, 09:06:08 AM »
Thanks for all your inputs. I probably check, replace the coil then.
Offline Alan F.
« Reply #7 on: October 21, 2009, 04:49:32 PM »
Is it me, or do coils always tend to fail on rainy days?
« Reply #8 on: October 21, 2009, 06:25:45 PM »
Cold ones too.
Offline ColinMc
« Reply #9 on: October 21, 2009, 09:09:57 PM »
Or if you are lucky, just when you are pulling in your driveway in a snowstorm. My 97 Jetta GLS I used to have...ugh
Offline bert96
  • past ride
« Reply #10 on: October 22, 2009, 03:48:38 AM »
If you don't have spark AND fuel,it's probably your main relay,it's under the dash on the left side.I changed mine on my '93 but the other years seem to have the same problem too.
http://media.photobucket.com/image/civic%20main%20relay/ajohnmeyer/IMG_4816.jpg
Yours, will looks pretty much like this
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline bert96
  • past ride
« Reply #11 on: October 22, 2009, 03:50:09 AM »
Offline mark
« Reply #12 on: October 23, 2009, 10:24:50 AM »
all these guesses and nobody said "igniter"?
bad coils are incredibly rare.
good luck.
F you mark...... F you.
Offline Alan F.
« Reply #13 on: October 23, 2009, 10:41:19 AM »
good luck.
Does an 89 civic have one?
Bert
Yup always carry a spare relay for troubleshooting when you have a Jetta.
Yeah I had a 94 GL.........UGH is about right.
Offline mark
« Reply #14 on: October 23, 2009, 03:07:10 PM »
good luck.
yep. and that's what the pic is. used '89-'91 IIRC.
Offline Alan F.
« Reply #15 on: October 25, 2009, 01:19:35 PM »
I guess you've never had a Jetta... ;D
Offline mark
« Reply #16 on: October 25, 2009, 03:56:09 PM »
no. and if I had, I would probably be too busy replacing their busted cheesy window regulators to notice a bad coil.
 :P
Offline Alan F.
« Reply #17 on: October 25, 2009, 06:32:04 PM »
 :P
I was at least smart enough to choose one without power windows.
