Author Topic: Anyone used the carb kit from Partsnmore?  (Read 1849 times)
Offline BigBoi
  • It's a jungle out there.
« on: October 22, 2009, 06:31:25 AM »
I just cleaned my first carb, refreshed it with a carb kit from PartsNmore. (K2 bike, carb is a 657A)
Everything went well except that I have this black O-Ring left from my kit. I was careful while taking it apart and didn't see this O-ring anywhere. Can someone who used it tell me where it goes?
One more note, I didn't take out the needle jet...I'm not sure if it has a gasket. Microfiches aren't helping...  >:(
nuggy00
Re: Anyone used the carb kit from Partsnmore?
« Reply #1 on: October 22, 2009, 11:14:04 AM »
drain screw oring?
Offline Steve F
« Reply #2 on: October 22, 2009, 11:19:33 AM »
Can't tell the size from your pic.  How big is it?
Offline BigBoi
« Reply #3 on: October 22, 2009, 11:45:36 AM »
I'll take pictures when I get home compared to the rest of the kit.
Offline daewon774
« Reply #4 on: October 22, 2009, 12:49:34 PM »
put a ruler next to it
76' CB550
11' Ducati 848 EVO
Offline BigBoi
« Reply #5 on: October 22, 2009, 02:22:15 PM »
As promised guys...thanks again.
Offline Ace
« Reply #6 on: October 25, 2009, 03:13:57 AM »
O ring (7.8x1.9) that fits (1 each end) on the end of the fuel joint (metal) that links both carbs?
1971 CB750 K1 - Sold
1978 CB750 F2 Supersport - Sold
1981 CB900 Bol d'or - Sold
2006 CBR1100 XX Super Blackbird - Sold
Offline wrenchmuch
« Reply #7 on: October 25, 2009, 05:47:56 AM »
Most kits I've seen don't supply o-rings for the t- fitting joining the carbs . What nuggy oo said . Bowl drain screw .
CB750K1
CB750K4
« Reply #8 on: October 25, 2009, 07:42:15 AM »
Some of the 750s had O-rings on the choke arm's shaft: that looks like it would have been one of those. The 657A/B carbs don't use them.
I hope the kit(s) did not include needles: the PartsNmore needles are Keyster, which are dead wrong for these 750s. Don't change the needle jet with Keyster parts, either. If you do, you will siffer flat spots and black sparkplugs, and cannot tune it out: go back to the Honda needles and needle jets. They don't wear out until about 90,000 miles, anyway, and even then, you can drop the needles one notch and compensate out the wear. Keihin was pretty smart about them..  ;)
Offline BigBoi
« Reply #9 on: October 25, 2009, 04:02:14 PM »
Turns out it was the bowl drain screw. I couldn't get it off so I had forgotten about it. It's all good...thanks for the input guys.
However, this issue with needles. I did use the ones provided in the Partsnmore kit. I put them side by side to the needles that were in the carbs and they seem identical. Is this possible? Has anyone else had a bad experience with these needles?
« Reply #10 on: October 25, 2009, 08:13:16 PM »
They may be the same length, but the Keyster tapers are quite different. This can be measured with calipers on a 12-point range, end-to-end of the needle. Thousandths of difference are very important here, as a difference of just .003" at, for example, the first width of the tip, will make the fuel change by 7%. It's very precision...if your new needles have a number like "27201", they are Honda's Keihin needles. If not, most Keyster needles have a 1, 2, or 3 -character identifier engraved on them.
If you search the forum for "keyster" you will find many tales of woe about them, at least with their needles: fouled plugs and erratic performance are the symptoms.  ;)
