Author Topic: There IS a difference in gasolines  (Read 1574 times)
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« on: October 22, 2009, 11:42:44 AM »
Last Saturday, decided to take my S90 for last ride of the season. Needed gas and the only station was a Speedway (owned by Marathon). Filled up and rode about 50 miles. Last evening I went to the barn and had a puddle of gas on the floor under it. Appeared to be leaking from petcock. WTF? Removed the tank and when I unscrewed the sediment bowl the rubber o-ring came out in several, sticky pieces. Had been in bike for 2 years. My brother-in-law (who is an ASC certified mechanic) stopped over and when I showed it to him, he asked if I had recently filled tank. Had just been at a tech school on fuel and E85 damage. Said Speedway uses up to 15% alcohol and that was the problem. Have used BP exclusively for years with no problem. Said to put 1 pint of fuel in a glass jar (not plastic)and add a small amount of water. Wait about an hour and the alcohol will settle to the bottom. Sure enough, the bottom 15% was clear alcohol. Alcohol eats rubber carb parts in a matter of hours. Thank God I learned this from the S90 and not the 550!
Fonda Honda
Offline Inigo Montoya
Re: There IS a difference in gasolines
« Reply #1 on: October 22, 2009, 12:46:26 PM »
Strange, I just fill with whatever here as virtually everything has ethanol in it, but only 10%.
I have never had that happen. Not saying it didn't to you but I just wonder if it was solely the alcohol.
Offline myhondas
  • Not really such a
« Reply #2 on: October 22, 2009, 12:51:12 PM »
BP uses ethanol.
The only main brand that I know that doesn't is Shell. So that is what I use in the bike and cage. Never had a problem. In Ohio, there used to be a law that the stations had to mark their pumps with what was in the gas. But our wonderful(cough a$$holes cough) lawmakers knocked that one off the books.(payoff cough)
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline 333
  • Time for change
« Reply #3 on: October 22, 2009, 02:08:15 PM »
Ethanol doesn't eat all rubber.  And if you've done complete overhauls on carbs with new parts in the last 15 or 20 years, it should be okay.  And it is my understanding that all gas nationwide has 10% ethanol.  Not much we can do about it.
Not to turn this political, but I choose my gas based on where the oil comes from.
http://www.terrorfreeoil.org/
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline tramp
« Reply #4 on: October 22, 2009, 02:12:35 PM »
never knew that
1974 750k
Offline cookindaddy
  • I sure love this bike!
« Reply #5 on: October 22, 2009, 02:29:41 PM »
When you say "rubber" do you mean neoprene? I thought that neoprene (which is what most modern black o-rings are made of which are intended for automotive use) was safe with ethanol.
"Neoprene: offers a high level of protection from oxidizing agents, alcohols, oils, fuels, alkalines, benzene, ethanol, hexane, isopropanol, and various acids;"
http://www.rencogloves.com/mat4.htm
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #6 on: October 22, 2009, 02:50:51 PM »
BP uses ethanol.
shell uses ethanol too, at all my local stations up to 10% however i use only shell as to me anyways, it seems to be the cleanest gas out there.
Mark Twain - Notebook, 1894
Offline Really?
« Reply #7 on: October 22, 2009, 03:56:40 PM »
Shell uses 5 times the EPA minumum of detergent.  I think Racetrack gas uses the EPA minimum.
I used to use Racetrack gas in my XVZ12DN.  I got tired of having to clean the cards every 4 to 6 months.  I switched to Shell and have not had to do that anymore.  That has been about 2 or three years now.
On the 750, I switched it to Shell and it looked to melt the liner that the PO put in it.  Go figure.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline grumburg
« Reply #8 on: October 22, 2009, 04:11:21 PM »
The oring was NOS Honda. Not enough left to tell what type of material. :P  No probelms with BP in 10-15K miles on my 550 and other old bikes.
Fonda Honda
« Reply #9 on: October 22, 2009, 05:52:39 PM »
I've always been a Shell fan. My neighbor is a territory manager for Valero. He tells me that Shell here in Colorado buys their gas.
Offline 333
  • Time for change
« Reply #10 on: October 22, 2009, 05:59:24 PM »
It was in the news a month or so ago that Shell just signed an exclusive deal with Iran.
Yes, I meant neoprene.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #11 on: October 23, 2009, 02:36:46 PM »
Yep, Marathon uses a lot of ethanol in their petrol.
Offline myhondas
  • Not really such a
« Reply #12 on: October 23, 2009, 06:48:54 PM »
BP uses ethanol.
Shell's V-power  has N O  ethanol in it !  Some of their 87 regular gas can have it but according to shell, they do not blend ethanol in their high test fuels. Depends on the distribution area that serves you whether or not your fuel will have ethanol in it. Even some of their mid range fuels can contain ethanol, but it again depends on your area.
SOHC# 5105 11228
Offline Bodi
« Reply #13 on: October 25, 2009, 03:44:37 PM »
Hmm.
I'll use any gas... except Shell. Their gas just fouls up the bike or car, whenever I'm running dry and the only station in sight is Shell... I buy it but know to expect stalling, misfires, hesitation, hard starting.
For a while Shell gas supposedly destroyed Ford or Chrysler fuel pumps, with a "secret" replacement plan. This did not happen to me and is probably an urban myth, not sure.
I definitely notice problems with the stuff though.
I prefer Sunoco for the bike (Canada) but use whatever's cheapest for the cage - except Shell.
Offline 333
  • Time for change
« Reply #14 on: October 25, 2009, 05:48:26 PM »
Now that's something I don't get.  Anything I own that runs on gas gets the same gas.
