Author Topic: neutral light switch  (Read 1766 times)
Offline topgun
« on: October 22, 2009, 11:41:50 PM »
ever since i put a new neutral light switch in, the gear changing has become quiet hard and finding a lot of false neutrals  it is a 750/4F1
Offline w1sa
Re: neutral light switch
« Reply #1 on: October 23, 2009, 01:16:51 AM »
False neutral lights (as in, neutral light while in gear) or false neutral gear (as in, selects to neutral instead of going thru to selected gear)?
Offline Gorms
  • Barkeep! Give me a beer and a
« Reply #2 on: October 23, 2009, 06:34:59 AM »
It may be a matter of rotating the arm assembly so that the lobe contacts it only while in neutral.
Offline topgun
« Reply #3 on: October 23, 2009, 12:09:42 PM »
sorry guys i should have been more specific, since fitting new switch ,gears are near impossible to select,it seems to put too. much pressure on the selector shaft, i pull the switch out it frees up ,is there a trick to it. i just got it registered and keen to put up some miles  regards tony
ajracer
« Reply #4 on: October 23, 2009, 12:30:12 PM »
I have a cb550 apart right now not sure if they are similar but here it goes. the neutral safety lobe attaches to the shift drum and has a little notch that locks it in. check to see if these notches are lining up. go through the gears with both side cases off and make sure nothing is rubbing. when you screw on the lobe it should be able to get finger tight and then a final crank with the screw driver. also the lobe doesn't need to put a lot of pressure on the contact when in neutral, just touching. hope this helps.
Offline mcpuffett
« Reply #5 on: October 24, 2009, 10:51:29 AM »
you have to make sure the bike is in neutral before you fit the switch as it locates into an indent on the selector drum  ;) cheers Mick.
Offline topgun
« Reply #6 on: October 24, 2009, 12:00:06 PM »
thank you for your replies,got it all sorted,
