Author Topic: CB650 Head  (Read 1241 times)
Offline Elkie
CB650 Head
« on: October 23, 2009, 05:22:39 PM »
Wanted to confirm what I read in a post I can't find anymore. So only the 79/80 head will match the 750 carbs? I picked up a 81 engine, but before I buy carbs I wanted to figure out what can fit. If I can't use 750 carbs am I limited to the stock 650's? Thanks in advance.
Offline cb650
Re: CB650 Head
« Reply #1 on: October 23, 2009, 06:40:53 PM »
Yes the 79/80 will work. The 81/2 has a wider spacing.
Offline Elkie
Re: CB650 Head
« Reply #2 on: October 23, 2009, 08:09:40 PM »
Thanks for the confirmation, I read in another post that kawa ninja 600 carbs will work on the later head any idea what years of the 600 these are?
Offline Pinhead
  • 1979 CB652-ST
Re: CB650 Head
« Reply #3 on: October 23, 2009, 08:31:26 PM »
I believe there are different manifolds to adapt 750 carbs to the later heads. IIRC, you have to also use the Ninja intake boots to make the carbs work. Don't quote me on it, though.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline Elkie
Re: CB650 Head
« Reply #4 on: October 23, 2009, 09:19:07 PM »
looking at a set of carbs off a 95 ninja the boots angle inwards, still looking for pics of other years.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: CB650 Head
« Reply #5 on: October 23, 2009, 09:26:54 PM »
PM Soos about the ninja carbs for that head.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline faux fiddy
  • bike in a box
Re: CB650 Head
« Reply #6 on: October 23, 2009, 10:31:19 PM »
Wider spacing, or whatever where there's a [person with] a will there's a way.
This is a recently completed project a friend had to do. After adjusting and modifying, jetting, grinding needles and anything else he could do to his rz he realized that his mikuni conversion would be much easier without so dang many screws getting to the carbs, but still use the stock air box.
The solution was to make the velocity stacks slightly eccentric. I takes careful measuring, a cnc machining center and cam programs.
ANYTHING CAN BE DONE!
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
