Author Topic: Back Firing?  (Read 950 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
Back Firing?
« on: October 23, 2009, 06:08:49 PM »
Hey I am fairly new to bikes, I picked up a 1975 CB550 about 2 months ago. I tore the carbs apart and broke a piece so I went to a local pick and pull and got a used set. I was too afraid to mess with them, they were gunked up and I put them on the bike. The bike sounds like its about to explode whenever I start it. I have a little black smoke coming from the exhaust and one of the exhaust heads. It has a 4 into 1 exhaust by the way.
When I got it running it back fired quite a lot and ran very unevenly, some of the pipes were super hot, others were kind of mild. Everyonce in a while a fireball would shoot out of the exhaust when it back fired.
Is this bike toast? What does backfiring mean?
Its hard to be wrong when you know nothing!
Offline the technological J
  • deliciouso!
Re: Back Firing?
« Reply #1 on: October 23, 2009, 06:26:55 PM »
no your bike is just outta wack with any luck you should be able to tune it  and have ur way with her.... if its not a valve problem.... if you know of anybody that cleans carbs go for it... if not get some sea foam and run it  every tank for a while..... download a manual and do a 3000 mile tune up (valves timing points.. just make sure the carb screws are set at the right level) but take her for a ride after that and let her clean herself out
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline w1sa
Re: Back Firing?
« Reply #2 on: October 23, 2009, 06:32:56 PM »
All sound like nothing is as it should be, to properly operate the engine. Out of service/tune carbs, engine service, leaky exhaust gasket(s) etc.
It's not practical to just install wreck yard carbs on your bike, especially since you won't know their internal set-up or condition. If your bike falls into a similar category you've increased the chances of failure or possible damage by subjecting the engine to further abuse.
As mentioned, Search the manual,service and tune-up procedures and acquaint yourself with doing that and also clean, inspect and set-up the carbs (per service instructions and available posts)in a condition to do the engine justice.
You'll be surprised at the different results......... :)
Ignoring any other yet unknown/possible hurdles
Offline OldSchool_IsCool
  • Really feeling like an
Re: Back Firing?
« Reply #3 on: October 23, 2009, 06:34:02 PM »
Which pipes are hot and which are only warm?  The ignition on these bikes are pair the cylinders.  If a pipe and it's pair are only warm, then you may have an ignition problem and not necessarily carbs.  The back fire would then be the result of unburned fuel from the warm pair hitting the hot exhaust from the hot pair when they merge in the accumulator leading to the single muffler.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Re: Back Firing?
« Reply #4 on: October 23, 2009, 07:13:27 PM »
These bikes respond well to a complete tune up.  And, this ought to be done before any carb work is accomplished.
