Author Topic: Wheel replacement questions? Mags?  (Read 1126 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: October 24, 2009, 11:07:16 AM »
Are there mag wheels that already come as a whole package that replace both front and back on a 1975 550? I mean, is there a compatible set somewhere that accommodates everything that the bike already has and can just be switched for the laced wheels?
Offline dave400
  • Super Lamb Banana
Re: Wheel replacement questions? Mags?
« Reply #1 on: October 24, 2009, 01:05:58 PM »
I would think you could get these type of wheels for the 550, I have a set on my 400 and I've seen 750's with aftermarket wheels also, look on ebay I got mine for a good price.
Cheers
« Last Edit: October 24, 2009, 01:07:52 PM by dave400 »
Offline Alan F.
« Reply #2 on: October 24, 2009, 01:55:25 PM »
There were several companies offering them back in the 70's.......
But the technology has been superceeded since then.
If you're going for a vintage look you'll need vintage mag wheels.
If you want to retrofit newer, lighter wheels that will accept tubless type tires and fit modern tire sizes, you've got your work cut out for you but it can be done.
If you want to go with modern gear, the planning begins with tire selection... choose your desired sizes and choose a specific tire that they're available in.
Then choose wheels that are sized to fit the tires you've chosen.
Then figure out your brakes, axle size and wheel bearing compatibility, find a sprocket to fit the needs of the new wheel and the old bike, and deal with the need to keep your chain line correct.  Swaps like this can rival the cost of rebuilding the stock spoked wheels and brakes with good quality parts and new tubes/tires.
It's not that hard and lots of are doing it.  to simplify the matter some are swapping the swingarm/brake/wheel as a unit, and the front end form the triple trees foreward, so as not to have to re-engineer too much.
I've got a ton of free info parked at http://sites.google.com/site/alansdocuments/
Do some reading and write down every thought for future reference.
-Alan
