Author Topic: Dry clutch on CB750  (Read 133014 times)
Offline voxonda
Re: Dry clutch on CB750
« Reply #325 on: May 09, 2010, 01:07:44 PM »
Hey G,
Well that was worth the waiting isn't it? Well what we are going to do is to testrun it and in the meantime decide on the price.
There is some additional work involved like harden/hardanodising some surfaces. But it is getting there, like I promised.
Keep in touch, buddy.
Cheers, Rob
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #326 on: May 09, 2010, 02:01:54 PM »
damnit man, that sounds amazing! that made me smile almost as much as a live Grateful Dead performance does!
Mark Twain - Notebook, 1894
Offline mick7504
« Reply #327 on: May 09, 2010, 08:25:51 PM »
Congratulations Rob.
That is an excellent achievment.
If I was you
I'd be worried about me.
« Reply #328 on: May 10, 2010, 02:10:28 AM »
G'Day Rob, I'm buying one of Cycle X's lock up clutches for my 1060cc "Cobra" project, I wonder if you could adapt your dry clutch conversion to suit? It'd be pretty cool to have a dry lock up clutch! Cheers, Terry. ;D
Terry,
If your useing Barnett plates leave the washers off the bob weights to start with.
Brian
Hey thanks Brian, I'll keep that in mind! ;)
Rob, that looks bloody fantastic mate, well done! (where's the "two thumbs up" smiley?)  ;D
Offline mick7504
« Reply #329 on: May 10, 2010, 05:42:51 AM »
[/quote]Here he is Terry.
A big one for Rob.
If I was you
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #330 on: May 10, 2010, 09:30:33 AM »
hey rob, could you give me/us some more information on your cable pull for the rear brake?  did you do this for weight savings?  i've seen some other threads about it, but no really conclusive reasoning for why it's done.  thanks!
« Reply #331 on: May 10, 2010, 09:50:22 AM »
With a solid rod, the brake pressure inside the drum changes as the wheel goes up and down regardless of the fact that your foot pressure may be exactly the same. Say your leaned over and have your foot on the rear brake and go into a dip or hit a bump. As the wheel goes up, the rod effectively shortens and the brake gets tighter, may cause you to lose traction.
A cable or hydraulic system doesn't do that.
Offline voxonda
« Reply #332 on: May 10, 2010, 10:09:59 AM »
Hey G,
There you have it, thanks Ron, amongst other reasons like disliking the way it looks with a rod and no need to adjust when adjusting the chain or in case you're racing lengthen your wheelbase by/or change gearing.
Rob
Offline wannabridin
  • -Garrett
« Reply #333 on: May 10, 2010, 10:37:58 AM »
thanks guys!!  any insight as to where you got the pieces for the kit?  what you did to rig it up?  thanks again!!  now go get some miles on the clutch so you can make me one!!   ;D ;D
Offline voxonda
« Reply #334 on: May 10, 2010, 10:45:58 AM »
All homemade!
Offline wannabridin
  • -Garrett
« Reply #335 on: May 10, 2010, 12:03:05 PM »
figures...  did you weld on a "ring" or "collar" to the rear brake drum to hold the outer sleeve of the cable?
Offline voxonda
« Reply #336 on: May 10, 2010, 02:56:20 PM »
Welded a collar on the backplate.
Offline CBJoe
« Reply #337 on: May 10, 2010, 03:04:32 PM »
I think that Paulages used a cable guide from a CB350 (or CB350T) Hub....
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline voxonda
« Reply #338 on: May 11, 2010, 12:27:54 AM »
While the clutch is running in the CR836, finished the 'road-engine'. Honed the cylinders slightly, while they where well within spec, and cleaned the pistons and mounted them with new rings. New primary's and stronger camchain and put in a 41a webcam. So this can go into the rolling chassis. Clean up the carb's and put on some nice stacks.
« Last Edit: May 12, 2010, 07:13:28 AM by voxonda »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #339 on: May 11, 2010, 04:24:34 AM »
That's good,but what about after lunch?  ;D ;D ;D....you one busy man,Great Work and Thanks,Bill
BentON Racing Website
BentON Racing Facebook
  • Moderator
« Reply #340 on: May 11, 2010, 04:29:27 AM »
you're up early Billy, you busy too?
Sam. ;)
Offline wannabridin
  • -Garrett
« Reply #341 on: May 11, 2010, 06:08:09 AM »
awesome rob!!  can't wait to read about how well it will do!  nice work!
and i remember the discussion about the 350 hub, but i don't think it was a direct swap, so i'm not 100%.  thanks for the picture and the information on your setup though!
Offline BLUE71TURBO
« Reply #342 on: May 11, 2010, 09:00:31 PM »
  I have 1 question about lockup clutches, are they any good for the street ?  It seems that I have only seen them on dragbikes.
  • Moderator
« Reply #343 on: May 11, 2010, 09:35:25 PM »
Damn Terry :o :o :o you taking up drag racing. ;D ;D ;D ;D
Sam. ;)
 ::) ;D :D ;)
« Reply #344 on: May 15, 2010, 06:12:49 PM »
Well I ordered it on Thursday mate, so I'll let you know. One of my other infatuations is big GS Suzuki's, and there are a few members on "The GS Resources" site who are running lockup clutches on their road bikes, with good results. I'm installing it on my K1 with the K6 836cc race engine with the horrible Barnett clutch, so as I said, I'll let you know! ;D
Offline bear
  • Leeton in Australia
« Reply #345 on: May 15, 2010, 08:17:17 PM »
I ran a locker in all my speedway chairs, don't see a problem running them in a street bike.
They can bite you on the arse if your not carfull though.
I wouldn't run a lot of weight on the cams in road bike.
Brian
Offline voxonda
« Reply #346 on: May 16, 2010, 02:14:40 AM »
Yes Terry, please keep us informed. Wonder if you'll need a lock up on our setup.
Cheers, Rob
« Reply #347 on: May 16, 2010, 02:21:33 AM »
Cheers, Rob
Thanks Rob, I'm looking forward to you taking orders for your dry clutches, so I can get one for my gold K2/F2. Hey, does the dry clutch use normal CB750 clutch plates (OEM or aftermarket) or do you need special plates now that it's not oil bathed? Cheers, Terry. ;D
Offline voxonda
« Reply #348 on: May 16, 2010, 04:47:28 AM »
[/quote]
Terry,
No, the kit will be provided with a complete set of plates with material like Ducati uses on their dry clutches. The diametre of the plates is smaller then OEM in order to create room for the outer basket.
Rob
« Reply #349 on: May 16, 2010, 05:03:25 AM »
Any idea on a price yet Rob?  Have you giving it a good run yet? I am really liking what you are doing here mate.... ;)
