Author Topic: starter motor safety unit bypass  (Read 23380 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: starter motor safety unit bypass
« Reply #25 on: September 14, 2016, 10:38:08 AM »
What are the specs for the diode?   I've got the same issue on my 77.....
Thanks,
Pat
They are still available from Honda:
http://www.hondapartsnation.com/oemparts/p/honda/31700-124-008/rectifier-assy-silicon-stanley
I had found a source for $10 each, but I would have to do some research to find out where. I bought three of them at that price.
Edit: One of the other symptoms I was experiencing was that the starter would not engage in neutral with the clutch handle out. I would have to pull the clutch in, even in neutral, in order for the starter to engage. The diode (called "rectifier" on the parts fiche) is usually suspended from a little rubber grommet on the back of the battery tray, above the plastic inner fender. Just follow the wires up to it, it's hard to spot!
« Last Edit: September 14, 2016, 10:42:57 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Pat_at_APE
    • APE Race Parts
« Reply #26 on: September 14, 2016, 11:14:46 AM »
Excellent info.... Thank you!
Pat
