Author Topic: Project "Low Brow"  (Read 43315 times)
Offline bikerbart
Re: Project "Low Brow"
« Reply #25 on: October 27, 2009, 03:57:04 PM »
spikeybike,Awesome build so far.I am doing my cb750 this winter,I am hammering dents in one of my tanks,thought about cutting it but the hammering is going well.I started a thread about it,have yet to update it.Too bad about your other bike,broke my heart when I seen the aftermath.Got a bunch of spares if you need any,let me know.Cheers
Offline honda_jason
  • I have no idea what I'm doing
  • 1971 CB500
« Reply #26 on: October 27, 2009, 04:47:24 PM »
me likey....me realllly likey...ill be watching this one. keep it coming!
« Reply #27 on: October 30, 2009, 11:41:54 AM »
read the next thread down in my sig ... i rebuilt it already
got some progress on the seat
added some more sheet for support , scrapped an old computer for the sheet metal , it had some pretty thick gauge on it so "chop, chop"
drilled some holes ... the open spaces on the sides is so i can run the wires for the tail/turn signals/tag light
so basically, the bar in the front will slide into a groove (that i haven't made yet)  then the back will be tightened with wing nuts from the underside ... not sure exactly how it's gonna work with the inner fender yet but... i'll figure somethin out
« Last Edit: October 30, 2009, 12:02:23 PM by Spikeybike »
« Reply #28 on: October 30, 2009, 11:49:31 AM »
oh and i forgot to mention that so far on this build  ... i have spent zero dollars   ;D ;D ;D ;D ;D
(my budget for the body is $100, witch will mostly be rebuilding the wheels.... and anyone who sets a budget on a motor rebuild...... has never rebuilt a motor  ;D ;D )
Offline nobody
« Reply #29 on: October 30, 2009, 11:54:09 AM »
I'm pretty curious to see how this thing turns out. I like your work.
74 cb750k
Offline Ogri
  • Thinks he's a
« Reply #30 on: October 30, 2009, 03:17:05 PM »
Bike's looking very good.
That weld is pretty bloody good for a newbie, you'll get no truck from me for teaching the little one how to handle power tools.
The French let their kids drink wine (watered down a little) as soon as they're off the teat, ever wondered why alcoholism rates in France are so small compared to other, more conservative countries?
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #31 on: October 30, 2009, 03:25:45 PM »
o
i found THAT out the hard way this year  ;D
Mark Twain - Notebook, 1894
« Reply #32 on: October 31, 2009, 03:00:30 AM »
well i ordered the 16" wheel ,spokes, and i had to get fork tubes as well ... $90 later, that above quote is either dead on ....... or a total pipe dream  ;D ;D
« Reply #33 on: October 31, 2009, 10:53:01 AM »
i just thought of a pretty good name ... since so far 100% of this build (and most likely the rest of it too) has been financed by me selling my blood plasma
 i thought "Blood Money" was pretty fitting
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #34 on: October 31, 2009, 11:03:00 AM »
 paint it red
« Reply #35 on: October 31, 2009, 11:27:22 AM »
nah .. i did red on the last one ...
so does anyone know what to use to clean up the pad surface on the rear drums... should i use Rolocs, and if so witch one .. can i get away with using a fine wire wheel on my drill .. some sort of chemical .... ?
got the seat attached o the pan and did some more shaving on it, once i get some neoprene from Inkscars i'll get the vinyl on it
oh.. and i found those signals in a box in my garage ... not totally sold on using them , but i most likely will since i already have them
i have discovered that an 80 grit "flap" wheel , that is almost used up is the #$%* for shaving seat foam ... in the past i've used 36 grit flat sanding discs .. witch can get a little sporty at times ...   but the 80 flap wheel (make sure it's a fairly used one) worked like magic, butter smooth , doesn't cut too fast or too slow
..... oh and i was also thinking of naming it "Freebie"  ... for obvious reasons
« Last Edit: October 31, 2009, 11:32:26 AM by Spikeybike »
  • Like a well oiled
    • Undead Asphalt
« Reply #36 on: October 31, 2009, 12:42:16 PM »
paint it patriotic red white and blue and call 'er FREEDOM. ;D :D
Offline mkramer1121
« Reply #37 on: November 01, 2009, 06:51:38 PM »
or you could not name it, get done w/ it, sell it, and split the proceeds...  ;D
Offline four_shot
    • For the Cherokee lover in you.
« Reply #38 on: November 01, 2009, 07:41:16 PM »
I like "low brow".  it sits well with me.  Im gonna have to get over there and look at it in person.  don't forget to call when you get the drum ready for me.
in memory of Dave "Gonzo" Steele
« Reply #39 on: November 01, 2009, 08:38:46 PM »
you sure i can't use a fine wire wheel chucked in a drill .... the 36grit Rolocs really scare me (don't wanna gouge it)  ... and i thought i had some of these
   but i don't  :'(
the wire wheel is way less aggressive then 36grit
Offline Sheik Yerbouti
  • Likes the warm feeling but is tired of all the dehydration.
« Reply #40 on: November 01, 2009, 08:43:43 PM »
Offline bucky katt
    • facebook
« Reply #41 on: November 01, 2009, 09:48:25 PM »
do you mind my asking how much they pay you for donating plasma? it's been many years since i've been inked so it should be ok now.
« Reply #42 on: November 01, 2009, 11:21:04 PM »
you have to go 3 sessions ..all on separate days (if you don't go all 3 times they can't use the plasma)
it takes under 2 hours each time
1st- $25
2nd- $40 (to motivate you to come back)
3rd-$25
then the process resets .... but some places give you the 3rd pay amount every time after your second visit
 it's easy money if you can handle needles, and pumping a machine full of your life juice
« Reply #43 on: November 02, 2009, 01:52:22 AM »
sanded the casting marks off with a 50 grit flap wheel
OMG i miss havin access to a plasma cutter, this #$%* took FOREVER
i'll show n tell the rest later , it's 4am ......... ZZzzzzzzzzzzzz
« Last Edit: November 02, 2009, 01:57:24 AM by Spikeybike »
Offline Peters1983
  • The young upstart of many forum wars
« Reply #44 on: November 02, 2009, 02:56:46 AM »
are those exhaust hangers or rearset mounts? regardless very well done, definitely like the way this build is going (kill me but I wasn't a big fan of the leopard print) very sleek and smooth, it fits the theme of the build.
Chuck dont need oil. Engines run cause they are afraid of chuck! ;D
« Reply #45 on: November 02, 2009, 09:16:08 AM »
passenger peg mounts
« Reply #46 on: November 02, 2009, 01:23:14 PM »
ok so ,  the combination of strong lights and a not so strong camera , are making it hard to shoot good pics....but anyway
the first piece was tacked on to my liking, i then used some threaded rod and nuts to get the other side straight and level in all directions ... then once they were both where i wanted them , i tightened up all the nuts to keep it from moving too much ...i was thinking they would move a little in one direction or another, but the nuts really did there job and they didn't move at all
« Last Edit: November 02, 2009, 01:25:06 PM by Spikeybike »
Offline Ogri
  • Thinks he's a
« Reply #47 on: November 02, 2009, 02:24:22 PM »
I like them very much, but.. isn't the swing-arm going to hit them when the shocks are compressed ?
« Reply #48 on: November 02, 2009, 02:34:41 PM »
come on man, that's a noobie mistake   ;D ;D ;D
they've got like about an inch and a half on either side .... the pic is a little deceiving
« Last Edit: November 02, 2009, 02:38:11 PM by Spikeybike »
JRK5892
« Reply #49 on: November 02, 2009, 05:49:26 PM »
this thing is coming out awesome! nice work man!!!
