Author Topic: Gauge project  (Read 20178 times)
Offline BurtonWarpup
Re: Gauge project
« Reply #25 on: October 27, 2009, 01:52:36 PM »
b82ta:
Any chance you want to make your file for the gauges available to others?
Mike
1.5x 1974 CB750K4
2003 Triumph Speedmaster
http://flickr.com/photos/mikepark/
"Now, with a hundred miles on the clock, the rider has nearly forgotten what it means to sit anywhere but on this machine." -Melissa Holbrook Pierson
Offline b82ta
Re: Gauge project
« Reply #26 on: October 27, 2009, 01:59:01 PM »
Can do.  What would you like them in?  I can do anything illustrator can export to.  Absolutely no guarantees on accuracy as I did them over a scanned image of an old tach I had, and an image of a speedometer that I found on this site...
Re: Gauge project
« Reply #27 on: October 27, 2009, 02:48:43 PM »
Excellent. The .ai file would be great. Thanks man.
Mike
1.5x 1974 CB750K4
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #28 on: October 27, 2009, 03:09:16 PM »
are you doing these using vectoring?
Offline Sheik Yerbouti
  • Likes the warm feeling but is tired of all the dehydration.
Re: Gauge project
« Reply #29 on: October 27, 2009, 03:24:42 PM »
Chances are they're vector if he's in illustrator. I'd like to see the files too. I'm debating on reviving my old gauges or just saving some time and headache with an acewell.
Offline b82ta
Re: Gauge project
« Reply #30 on: October 27, 2009, 03:41:09 PM »
I'm tracing over existing images/template photos in illustrator.  They are vector images, and therefore can be easily manipulated via layers, fills and line weights.  I'm in the process of cleaning up my files and will upload them when they are a little more tidy.  also for the speedo tach combo gauge... What are the gearbox ratios for the F bikes?  I tried using values that I found on the forums, but its not coming out to anything close to my current speedo readings... I suppose I could be using the wrong sprocket tooth counts...
Offline Henning
Re: Gauge project
« Reply #31 on: October 27, 2009, 04:38:36 PM »
Nice! My 2c is, drop the "RPM x 1000" and just write "RPM", like on the blue guages. Gives more symmetry between the guages, three letters each.
71 or thereabouts 750 K1 - this one should have been put down
Offline b82ta
Re: Gauge project
« Reply #32 on: October 27, 2009, 04:56:42 PM »
Ah, great idea.  Thanks.  Also, I got the gear ratio issue figured out. Nearly have the speedo/tach combo gauge designs done.
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #33 on: October 27, 2009, 05:18:26 PM »
with that combo your "speedo" would only be accurate in 5th gear. mine is 57mph@4000rpm
 I don't know about you but I ride in 4th alot...
 depending on the speed, whatever keeps me above 3700rpm
Offline b82ta
Re: Gauge project
« Reply #34 on: October 27, 2009, 06:14:36 PM »
Alright, so here are the base designs for the Speedo/tach combo.  Apparently I didn't have the gear ratios figured out as there is a discrepancy between the two sources... For the gauge with 2-5 on it I used the excel sheet in the technical info section.  I changed the values of the 4th and 5th gear as well as the primary reduction as per this thread. http://forums.sohc4.net/index.php?topic=49373.0  Using my 14/43 sprocket combo, these are the values I got.  For the other gauge I had used information compiled from the same thread but used a different online speed vs rpm convertor.  Anyway, all of this can be easily corrected before the gauges are finalized granted I know what caused the difference... and which one is correct.... anyway here they are!
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #35 on: October 27, 2009, 06:38:19 PM »
I like the second one, it reminds me of cockpit gauges.
Offline the technological J
  • deliciouso!
Re: Gauge project
« Reply #36 on: October 27, 2009, 06:48:21 PM »
i kinda like the one on the left... but doesnt tire wear, chain and sprocket wear come into factors? as well as i heard these tachs can be off by 100 rpms... i think its a cool but i dunno if it would be worth the hassle... some one mentioned a thread earlier of another speedo tach combo but one was normal size and the other was like an inch diameter and in the middle upper right...if anybody knows where that thread is post it cause its cool... but if u like it... thats all that mattters
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline b82ta
Re: Gauge project
« Reply #37 on: October 27, 2009, 07:03:50 PM »
I don't think it would make too much of a difference. The amount that tire wear would throw it off couldn't be all that much?  I don't really give too much credit to either the tach or speedo on these bikes as being overly accurate.  The speedometer on mine is 5+ mph off.  These are just messing around anyway.
Offline b82ta
Re: Gauge project
« Reply #38 on: October 27, 2009, 10:20:53 PM »
alright guys, for anyone who's interested.  .ai format of the first two designs are up.  Here's the link.
http://www.filefactory.com/file/a07ed55/n/Gauge_template_ai
If there is interest in the combo gauges being uploaded i'll clean them up and get them up as well.
thanks for the feedback guys, hopefully more progress soon, the new laser cutter sheets go up tomorrow morning and I'll try to get myself a slot early in the week...
« Last Edit: October 27, 2009, 10:29:22 PM by b82ta »
Re: Gauge project
« Reply #39 on: October 29, 2009, 06:47:19 AM »
Thanks so much for the files b82ta.
In case anyone needs the Eurostile font that's used here, you can download it for free at http://www.webpagepublicity.com/free-fonts-e3.html.
Mike
1.5x 1974 CB750K4
Offline b82ta
Re: Gauge project
« Reply #40 on: October 29, 2009, 08:24:09 AM »
Not a problem!  I did forget about that font not being one most would have... should have included that link as well, but thanks for throwing that up.
Offline b82ta
Re: Gauge project
« Reply #41 on: November 06, 2009, 10:39:28 AM »
Alright, well I got on the laser cutter today, infact I'm actually waiting for the raster engrave to finish. This cutter is soooo slow....
Offline b82ta
Re: Gauge project
« Reply #42 on: November 06, 2009, 01:04:46 PM »
Ok so here's what I've got so far.  All cut, etched and ready for paint.  Hopefully there will be more progress soon.
  • Like a well oiled
    • Undead Asphalt
Re: Gauge project
« Reply #43 on: November 06, 2009, 06:47:46 PM »
pretty
Offline mystic_1
  • 1970 CB750K
Re: Gauge project
« Reply #44 on: November 06, 2009, 08:25:29 PM »
mystic_1
- John Augustus Shedd
Offline Joel
Re: Gauge project
« Reply #45 on: November 06, 2009, 09:58:02 PM »
I'd suggest doing regular intervals, such as every 10 MPH, on the speed scales.
I wouldn't think it would be much worse than the stock speedo.  Mine is off by about 10 MPH at 60.  It's still better than nothing.
A great solution for those with tach only would be a small digital display showing through the face.
Offline new2novas
Re: Gauge project
« Reply #46 on: November 07, 2009, 08:42:45 AM »
dude...awesome!.....it woul be really cool to do the LED shining in the side so it only lights up the etched sections, and with no light it would look like the gauges were blacked out, or whited out :P.....really cool and so many awesome ideas can come from that
75 cb750F
Offline nobody
Re: Gauge project
« Reply #47 on: November 07, 2009, 08:50:50 AM »
Well that's fancy... I like it. What color do you plan to put behind it?
74 cb750k
Offline b82ta
Re: Gauge project
« Reply #48 on: November 07, 2009, 10:01:50 AM »
Lighting from the side would be awesome, but I don't know if they would be bright enough to not get completely washed out in the sun... At night it would be totally awesome.  I'll maybe have to test some stuff out with that. I'm not sure what I'm going to do for painting them both my plan and my plan b failed... The laser cutter didn't cut the plastic coating out over the etching like I had hoped it would and the etching isn't deep enough to paint the whole thing and sand the rest off. BUT I have a couple more ideas to try, and I have some extra time today so  I'll mess around a bit.
Offline new2novas
Re: Gauge project
« Reply #49 on: November 07, 2009, 10:34:30 AM »
man is that cool...wish i could be there messing around with it with ya :'( :'( :'(......i didn't think about daytime lol....you could paint everything but the numbers or whatever for contrast in day and still have the light shine through at night...
75 cb750F
