Author Topic: What am I doing wrong?  (Read 1126 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: October 26, 2009, 03:09:30 PM »
I can not get the grease off my swing arm and frame!! I am using a wire brush and Simple Green, but the stuff is just caked on. Is there something better than the simple green?
Offline Gorms
  • Barkeep! Give me a beer and a
Re: What am I doing wrong?
« Reply #1 on: October 26, 2009, 03:11:12 PM »
How worried are you about the paint?  Brake cleaner?
Offline Alan F.
« Reply #2 on: October 26, 2009, 03:21:19 PM »
Old business cards work well to remove caked on crud from most things.  Perhaps warming the crud with a hair dryer and heating your simple green solution will help accelerate things?
-Alan
Offline Magpie
« Reply #3 on: October 26, 2009, 03:24:21 PM »
Gunk grease remover works, the liquid brush on kind. The steel brush will be hell on your paint. If the swing arm and frame are bare a power washer will do it too. varsoll too.
Cliff.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: October 26, 2009, 04:18:35 PM »
Note: Magpie said bare, no motor or electrics on the bike, that's about the only time you would want to use a power washer on your motorcycle.
I would recommend not using one at all, they can screw up stuff you never thought you could screw up on your bike.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: October 26, 2009, 04:21:06 PM »
If it's caked on there real bad (chain lube?) then consider using a plastic putty knife to scrape off the worst of it.
In a pinch you could use the sharp end of wood shims, the blunt ends of bamboo shiskabob skewers, or anything similarly soft.
mystic_1
- John Augustus Shedd
Offline Really?
« Reply #6 on: October 26, 2009, 04:30:43 PM »
Good luck, that chain lube, oil and grime can become a flippin' rock.
A lotta rubbin' with gumout may work.  If the paint is still decent looking when you are done and not all tore up on the frame/swingarm, Meguires Cleaner Wax can bring back a good shine.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline robdrobd
  • Who? Me?
« Reply #8 on: October 26, 2009, 05:50:00 PM »
I am cleaning it to re-paint anyway! ;D
Offline lone*X
« Reply #9 on: October 26, 2009, 06:21:47 PM »
[/quote]
Then a good "sharp" putty knife and kerosene or varsol (cheap).
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
