Author Topic: new cylinder stud snapped??!!!???  (Read 1891 times)
vbtiki750
« on: October 29, 2009, 10:30:37 PM »
I've looked all over the site for a post on this topic and found nothing (searched my self to death) so I wanted to know if anyone else has had a new HD cylinder stud snap @20lb of torque not even the full 22lb thats recommended.  It was the 2nd in the sequence and now I dont trust the other 15 studs.  I still have the original studs and was thinking about using one of them rather than a whole new set at $80 >:(.  Does that sound like a defective stud?
Any info on how that would affect my rebuild would be helpful or any suggestions as to the torque I should use on the HD's considering one would be a stock stud.  Needless to say I have an injured toe from the swift kick I delivered to the nearest heavy object.  I have a 76 cb750 k3 if that makes a difference and the studs came from cyclex.
Offline mick7504
Re: new cylinder stud snapped??!!!???
« Reply #1 on: October 29, 2009, 10:58:06 PM »
It is very unusual for that to happen.
It would normally take a lot more than 20 ft/lbs to snap one.
If you have a close look at where the stud snapped, it will either be a clean break all the way across or if there is a fault with it you should be able to see some different discolouration in the metal.
Usually darker around the outside edge of the break and  the rest towards the centre a lighter colour.
Either way it would be better to keep a full set of HD studs on the job.
Cyclex are a good mob to deal with.
I think the best thing to do is to contact them and explain what has happened and they may be able to supply you with a replacement stud.
If I was you
I'd be worried about me.
vbtiki750
« Reply #2 on: October 29, 2009, 11:09:03 PM »
Looks like it snapped about 7 threads from the top roughly 60% across the stud then shot down about 3 threads to brake off completely.  I have dealt with cyclex for several parts and have a good repore with them so i'm thinking I'll give em a call once the sun comes up.  It just amazed me because i hear so much about the APE studs being so strong and the others held up so well I was shocked when it happened.  Thanx for the input
« Reply #3 on: October 29, 2009, 11:39:25 PM »
I'd like to think that CycleX or Big Jay (APE) will come through for you. Was the hole clean and DRY?
« Reply #4 on: October 30, 2009, 04:38:41 AM »
 I have had this happen to me but it was a bottom end stud. I was torquing down the nut (I use 3 stages) and on the final stage, probably at around 20lbs, the stud snapped diagonally. It sucked to be honest as the torque wrench went flying and i cut my arm on the jagged end of the stud. Dynoman replaced the stud no problem BUT my point is it has happened to me too.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #5 on: October 30, 2009, 05:02:57 AM »
Yeah,sh*t happens,just sucks to be on the short end,Ken @ CycleX sure to come thru(good people there),but definitely use H/D studs.Bill
BentON Racing Website
BentON Racing Facebook
Offline Alan F.
« Reply #6 on: October 30, 2009, 05:12:23 AM »
At least it broke near the top I suppose, and not flush with the case.
-A
vbtiki750
« Reply #7 on: October 30, 2009, 11:11:26 AM »
Thanx for all the feedback I called cyclex and they sent me a replacement at no charge.   They also said they have a bunch of new stuff coming out by the end of the year.  So by the time my toe heals up I should be able to put the engine in the frame.  thanx again! ;D
Offline mick7504
« Reply #8 on: October 30, 2009, 05:33:23 PM »
That is good news and shows that you are valued by Cyclex as one of their customers.
If I was you
vbtiki750
« Reply #9 on: October 30, 2009, 10:07:11 PM »
I tried to post a pic of the stud but my carea still doesnt work on its 8th set of batteries about $120 worth of batteries in a $800 camera thats 4 months old.  Needless to say I'm conditioned to delays and disappointment. I did get my rims sandblasted and painted in the meantime.
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: October 30, 2009, 10:16:45 PM »
I wonder what they're average out-of-box-failure (still birth) rates are on these studs?  Two people having failure reports in this size a community is more than I'd expect for this.
mystic_1
- John Augustus Shedd
Offline mick7504
« Reply #11 on: October 30, 2009, 10:36:28 PM »
mystic_1
That did go through my mind too.
If 2 that we know of have sheared at around 20lb, how are the others that have taken the correct torque hanging in?
Are they ok or just ok?
If I was you
vbtiki750
« Reply #12 on: November 05, 2009, 12:24:20 AM »
got the new stud and installed no breaks so lets just hope it was a fluke or two flukes total if thats possible
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #13 on: November 05, 2009, 01:12:01 AM »
who is the actual manufacturer of the studs? i wonder if it would do any good to just ask them about these failures, if they would give a truthful answer?
Mark Twain - Notebook, 1894
Offline mick7504
« Reply #14 on: November 05, 2009, 02:42:00 AM »
I purchased a set of HD studs from Cyclex a bit over 2 years ago with some other parts and they supplied APE studs.
No problem at all with those.
Maybe they have another offshore supplier now.
I know in the automotive game here in Oz that a lot of parts come in from SE Asia and beyond.
The cost of some of these parts landed here really makes you wonder how anybody can make a dollar.
The importers have shipping and handling costs before they make anything out of it.
25 years ago we would be paying a little bit more for items manufactured here and now all of those years later we can buy those same items imported cheaper.
I suppose the bottom line is working for 20 dollars an hour or 20 cents an hour as an example and also the quality control thing.
If I was you
Offline voxonda
« Reply #15 on: November 05, 2009, 03:16:56 AM »
I agree fully with Mick, thru voxonda.com I import and sell parts. Price is dictated more by taxes and shipping then by manufacturing today it seems.
Rob
