Author Topic: Shouldn't there be gaskets here?  (Read 1272 times)
Offline devriems
« on: October 31, 2009, 10:04:49 AM »
I'm ready to put the lower and upper cases back together on my 75 CB750K5 but I'm wondering if I am missing some gaskets.  Check out the pics.  I have highlighted in red where I would expect to need to put gaskets, but in my complete gasket kit from CycleX, I can't find anything that matches.  And, when I took the cases apart there wasn't any gasket material there.  I haven't scraped anything yet so what you see in the pics is how it was when it came apart.
Can anybody take a look at these and let me know if I'm crazy and I don't need gaskets when putting the cases back together?  Or maybe I just don't have all the gaskets that I need.  Any help is greatly appreciated.
http://devriems.blogspot.com/2009/10/gaskets.html
Offline CBJoe
Re: Shouldn't there be gaskets here?
« Reply #1 on: October 31, 2009, 10:26:49 AM »
This should answer your questions.
http://forums.sohc4.net/index.php?topic=28822.0
Regards, Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline devriems
« Reply #2 on: October 31, 2009, 10:37:32 AM »
In other words, there isn't a preformed gasket or gaskets for it.  You just have to use Hondabond and make your own "gaskets" to seal the case halves together, right?
Offline wrenchmuch
« Reply #3 on: October 31, 2009, 11:12:51 AM »
Thats right . The link CBJoe points to is correct . I put Three bond on one case half in a thin layer with a small brush and put the halves together . No leaks . It was Mrieck who posted the instructions I used .
CB750K1
CB750K4
