Author Topic: Any fireplace gurus in here?  (Read 513 times)
Offline Middler1
  • 1981 CB650C
« on: October 31, 2009, 04:58:22 PM »
Got a quick question for any experts in here. I can get an almost unlimited supply of plywood "drops" from work. They average 10" by 5" by 3/4". Since they're made up of separate layers of wood glued together, are they safe to burn in a fireplace, or should I just use them for bonfires outside?
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Any fireplace gurus in here?
« Reply #1 on: October 31, 2009, 05:01:29 PM »
outside bonfires
between the glue and the fact theyre likely made up of pine, theres the resin problem too. and make sure the pieces arent "marine grade" plywood as alot of times it's treated with arsenic
Mark Twain - Notebook, 1894
Offline Middler1
  • 1981 CB650C
« Reply #2 on: October 31, 2009, 05:16:09 PM »
That's kind of what I was expecting to hear. Oh well, it was worth asking. Thanks.
Offline tramp
« Reply #3 on: November 01, 2009, 08:49:17 AM »
if you decide to burn them keep the fire hot and the flue open
which you should do about once a week anyway
1974 750k
Offline BeSeeingYou
« Reply #4 on: November 01, 2009, 05:52:58 PM »
Be very careful about burning dimensional lumber in a fireplace.  2x4's, 1x4's, plywood, etc.  Aside from the glue in the ply, resin in the pine, and the possibility of the wood being treated, it burns too hot as it is much dryer than split firewood.  Use it as kindling or in small quantities may be ok.  I know someone who had a gazebo that he tore down and burned the remains in his fireplace.  The fire was so hot that it started a  small smoldering fire in the wall possibly through a loose or missing mortar joint.  Fire Dept came out, tore the wall open from inside the house and hosed it all down with a massive quantity of water.  Ruined the hardwood floors on the whole first floor, water ran downstairs and ruined a room in the finished basement.  They almost destroyed the house in order to save it. ;D
« Last Edit: November 01, 2009, 08:47:23 PM by srust58 »
