Author Topic: Did I get taken for a wheel truing?  (Read 4411 times)
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
Re: Did I get taken for a wheel truing?
« Reply #25 on: November 03, 2009, 11:42:44 PM »
I do them myself on an old set of forks and triple trees, and an old swing arm, and a dial indicator, Just remember to take measurements and come up with your offset average so the rim is centered correctly over the hub. You can always take your trued wheel to have it checked if you want to make sure. If you can talk to a mechanic, See if he can check it maybe get some pointers for a donation to the coffee fund. Has worked for me in the past for various things.    Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
