Author Topic: CB 450  (Read 8853 times)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: CB 450
« Reply #25 on: November 08, 2009, 08:00:29 AM »
It's the specific heat ratio I'm looking at. Why is is it 1.2 to 1.4? How do we calculate it's actual number? i.e what is specific heat ratio for a volumetric compression ratio of 11.5 to 1?
No.
Offline w1sa
Re: CB 450
« Reply #26 on: November 08, 2009, 04:45:30 PM »
The 'specific heat ratio' is a scientifically concluded exponent value applied to gas behaviour. The 1.2 to 1.4 simply provides a range to cover different conditions/assumptions included in any calculation.
In scientific speak, the 1.2 value is a polytropic value and the 1.4 is a dry air adiabatic value. The known value for air/methanol is apparently 1.3 (approx). The exponent value of 1.3 is also (apparently) highly favoured by individuals that theorise/design.
I did read one argument that stated the value of 1.2 (approx) was probably more relevant, since it served to cancel out other optimistic valve closing calculations etc and provide a more real world figure.
The exponent value chosen does not itself change for different calculations based on different CRs.
It's impossible to know what values Honda used originally. The calculations for engine design may well have been different to real world test results, which would dictate the 'workshop test' figures we see published.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: CB 450
« Reply #27 on: November 08, 2009, 05:26:31 PM »
Are you saying that the specific heat ratio does not increase with higher compression?
No.
Offline w1sa
Re: CB 450
« Reply #28 on: November 08, 2009, 07:16:09 PM »
How long is a piece of string? Is there a carrot at the end?
Is the string attached to a stick?     :P
That's correct. Not for calculation of cylinder pressure (cold/no ignition compression tests) at standard/room temperatures, using DCRs etc
Additional pressure in the cylinder requires significant additional heat (which occurs during ignition), at which point the effective/absolute cylinder pressures are far greater...... :)
