The only experience I have had with the Boyer was on an XS 650. On the XS the points assembly is on the cam and is replaced with a sensor and rod that goes through the cam(sensor on one side, threaded rod through the cam and locking nut on other side). Adjusting the timing was a PITA as the "point plate equilivant thing" didnt rotate for timing adjustment and the rod that held the spinning sensor had to be loosened and repositioned to adjust timing. I thought it was kind of a dumb arrangement that could have been designed better for easier timing adjustement.
Other than that, the Boyer has been on the bike for about 5-6 years and there has been no complaints with it. Reliable starting, runs great.
