Author Topic: 1977 CB550 F Choke question...  (Read 2783 times)
billyjack
« on: November 05, 2009, 11:49:43 AM »
Hello out there. I just picked up a 77' CB550 F, in fairly rough shape, but mostly there.  It does not have a choke knob/cable ???.  My question, did the bike come with a choke knob (up near the speedo) and cable setup originally, and if so, does anyone have pics of the linkage setup?  The carbs have a manual lever-type thing on the left side that i've been playing with, and that seems to be handling the choke duties, the bike starts/runs okay.
Any help is greatly appreciated!
Offline Gorms
  • Barkeep! Give me a beer and a
Re: 1977 CB550 F Choke question...
« Reply #1 on: November 05, 2009, 12:00:56 PM »
Yes this did come with a coke cable on the dash and it moves an arm in the middle of the carb bank (between 2 and 3) at the rear of the carbs.  The arm is a forked hook and there is a support above is that pinches the end of the cable tube.
Edit: I now see its a 550F and not a K.  Above is for a K, although the F may be identical.
« Last Edit: November 05, 2009, 12:42:17 PM by Gorms »
« Reply #2 on: November 05, 2009, 12:26:18 PM »
None of the 550 F models (any year) had a choke knob at the bars.  They used the earlier style carbs with the lever on the side of the carbs.
Only, the 77-78 550 K models with the PD style carbs have the choke knob and associated mechanism.
Offline Fritz
« Reply #3 on: November 05, 2009, 01:52:39 PM »
Hi!
No cable.
Here's a picture of the choke lever of a CB 550 F1 model. Your's should look the same.
/Fritz
1976 CB550F
billyjack
« Reply #4 on: November 05, 2009, 06:24:39 PM »
I got it.  I'm the F model, and my choke is indeed the lever depicted in the pic.  I appreciate your help, guys.  This forum is just incredible.  I could have easily seen myself chasing down the wrong components.
Thanks again guys.
