Author Topic: monoshock 750  (Read 52706 times)
Offline sander
monoshock 750
« on: November 06, 2009, 06:16:18 AM »
Hi all! I'm Sander from the Netherlands, new to this forums.
As my wheels were all wobbly, i thought i might as well put some modern wheels on my bike. Well you can guess the rest, plans got bigger and bigger...
So i bought myself this:
-cbr900 rearend (incl. monoshock)
-cbr900 wheels and brakes
-cbr1000 frontend (same inner bearing sizes, only a little longer stem)
A few pics of the new swingarm and shock..
Swingarm pivot bolt is 20mm so i had to make some new axleslots to fit the frame..
While i was at it, i made a new axle as well, because the cbr axle was to short for this frame..
Next thing to do will be mounting the forks and see how it fits..
Sander
« Last Edit: August 04, 2012, 07:46:08 AM by sander »
Offline wannabridin
  • Patience made me a
  • -Garrett
Re: monoshock 750
« Reply #1 on: November 06, 2009, 07:23:22 AM »
looks good, but how will the vertical mounted shock perform?  seems like it would be a bit harsh and have the tendency to fold under a little bit, if that makes sense.  i know almost every mono shock bike i can think of has the shock mounted a bit on an angle with the top towards the front of the bike.  have you tested out the function of this?
now what are you going to do with the front suspension??
Offline sander
Re: monoshock 750
« Reply #2 on: November 06, 2009, 07:32:09 AM »
Thanks!
On a stock cbr900 the shock is mounted this way. So it should work smooth. Also when compressing the shock, the bottom eye is rotating/shifting towards the rear due to the link system.
Front suspension is coming from a cbr1000f, but i still have to knock the old bearingcups out of the frame...
Re: monoshock 750
« Reply #3 on: November 06, 2009, 08:10:55 AM »
Very interesting and Ill be curious to see how this turns out.
Similar to this maybe?
cheers
Andy
Offline voxonda
Re: monoshock 750
« Reply #4 on: November 06, 2009, 08:31:32 AM »
Dag Sander,
Leuk om nog een landgenoot hier tegen te komen, welkom!
So that's enough dutch for today.
Interesting approach, am collecting parts to build a 'old style' monoshock 750.
Cheers, Rob
« Last Edit: November 07, 2009, 12:59:35 AM by voxonda »
Offline Alan F.
Re: monoshock 750
« Reply #5 on: November 06, 2009, 02:50:15 PM »
Very nice, check out the link in my signature line for some related reading material.
-Alan
Re: monoshock 750
« Reply #6 on: November 06, 2009, 03:02:21 PM »
Hello Sander, nice project mate. can you tell me what the "new" wheel base will be, how much longer will it be.? Was the swingarm the same width or did you have to alter it to make it fit.? Cheers...Mick
Offline MJL
  • Don't listen to me, I'm no
Re: monoshock 750
« Reply #7 on: November 07, 2009, 02:04:17 AM »
I've been wanting to do a monoshock for awhile now, but there's not enough room for the airbox, battery, etc along with the monoshock mounted horizontally. I thought about an underbelly setup like Buell used to use, but then I'm limited to a Buell shock. What you've got there is a great solution, but I'm concerned about the amount of leverage and the spring rate needed. I'll be watching to see what you come up with.
Offline bert96
  • past ride
Re: monoshock 750
« Reply #8 on: November 07, 2009, 02:43:15 AM »
 Where will you install the oil tank now ???
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline sander
Re: monoshock 750
« Reply #9 on: November 07, 2009, 06:31:44 AM »
Thanks for all the reply's!
Dag Sander,
Cheers, Rob
Hallo Rob! Ik ben benieuwd!
-Alan
I've read your topic, very interesting!
cheers
Andy
No i'm going for a more "classic" look, stock tank, cafe seat.. Nice bike though!
I don't know how much longer it is, i think about 4 inches. The swingarmpivot is 1 inch wider, so i cut and stretched the frame.
Bert
The shock has an offset to the left so the stock oiltank still fits. Just barely but it will do..
Sander
Offline fastbroshi
  • Puppet
Re: monoshock 750
« Reply #10 on: November 07, 2009, 08:48:53 AM »
This should be relative to what you're doing.  Pretty cool animation of the Pro-link in action:
http://images.sportrider.com/bikes/2004/2004-honda-cb1000-upl.gif
The swingarm looks like one from yours, but from a different model judging by the title of the link.  However I'd be willing to bet the bike you got yours from didn't have a solid mount, rather it probably had a dogbone link of some sort allow movement of the top eye of the shock to move in a circular plane.
« Last Edit: November 07, 2009, 08:51:44 AM by fastbroshi »
Just call me Timmaaaaay!!!
Offline nobody
Re: monoshock 750
« Reply #11 on: November 07, 2009, 09:00:59 AM »
This might give you some ideas for how this should be done.
from this site
http://www.eurospares.com/newadd.htm
74 cb750k
Offline Alan F.
Re: monoshock 750
« Reply #12 on: November 07, 2009, 09:27:36 AM »
I'm not worthy!  I'm not worthy!
Offline Alan F.
Re: monoshock 750
« Reply #13 on: November 07, 2009, 09:31:26 AM »
I would think that as long as the suspension geometry from the donor bike is kept, that all will be well and you can tune the suspension to the weight of the CB750 and the rider accordingly with different length dogbones and springs.
That TF pic is great, any more where that came from?
-Alan
Offline nobody
Re: monoshock 750
« Reply #14 on: November 07, 2009, 10:18:00 AM »
I have no more info on it. The website just has pictures, sure is a pretty machine though.
74 cb750k
Offline voxonda
Re: monoshock 750
« Reply #15 on: November 07, 2009, 10:38:23 AM »
That is the one Tony Foale build, an that is the style I am after. Straight forward concept.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Re: monoshock 750
« Reply #16 on: November 07, 2009, 12:03:18 PM »
 The 900 RR has the link that is shown on the CB 750 above. I was going to comment about the bottom frame mount being "solid", but if you look closely at the pics above, you'll see the suspension link inside the solid welded-on mount (Bolted to the front hole of the welded bottom mount on the frame and bolted to the bottom triangular bottom shock mount thing).
 The animation website link is for the later style CBR 600 style swing arm(and other CBR models). The later style swing (with the "floating top shock mount") would be nice for the CB 750 oil tank clearance issues that may arise with other monoshock mounts that would mount solid (simular to the 750 pictured above- although, this set up clears the oil tank).
 Looking good ,Sanders!
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline voxonda
Re: monoshock 750
« Reply #17 on: November 07, 2009, 12:29:52 PM »
On my (ex-)Martin framed 750 the oiltank was wrapped around the shock.
A lot is possible.
Offline bigsherm
Re: monoshock 750
« Reply #18 on: November 07, 2009, 05:49:36 PM »
Here's a design I worked on.  It's based on the measurements of the '78 CB750 frame, with the stock swingarm braced and using a '90's Ducati 900/750SS shock.
This brought the top of the shock near a junction of the frame tubes that would provide good strength, very similar to the awesome Tony Foale monoshock bike.
I did my best to mock the Ducati geometry, and ensure a rising-rate compression of the shock.
The seat support subframe tubes were moved in the drawing, like Benjie's Cafe Racers likes to do, but that is cosmetic, and the rest of the frame geometry is modeled after technical drawings from Honda.
Sherm
« Last Edit: November 07, 2009, 05:57:07 PM by bigsherm »
Offline sander
Re: monoshock 750
« Reply #19 on: November 08, 2009, 01:37:52 AM »
Thats a nice setup Rob! Do you have more pics of that bike?
The Tony Foale bike looks good, allthough i don't like the seat that much.
I have some pictures of the original 900RR shock. See if i can find them...
Offline sander
Re: monoshock 750
« Reply #20 on: November 08, 2009, 01:51:02 AM »
Found them..
I came across some other inspiration pics.. this is the look i'm after
Offline sander
Re: monoshock 750
« Reply #21 on: November 11, 2009, 01:54:17 AM »
I've got a little update on the bike...
I've replaced the bearings and put a spacer under the lower one to fit the forks in. The spacer is about half an inch.
« Last Edit: November 11, 2009, 04:15:59 AM by sander »
Offline KB02
Re: monoshock 750
« Reply #22 on: November 11, 2009, 05:32:36 AM »
Looking good.
That frame looks so wimpy compared to that swingarm.  ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline fastbroshi
  • Puppet
Re: monoshock 750
« Reply #23 on: November 11, 2009, 07:43:27 AM »
Cool!  Looking good my friend.  Might as well add some gussets and one of Gordon's (I think) frame mods while you're at it.  Almost forgot to ask, is that a 16 or 17 inch front wheel?
« Last Edit: November 11, 2009, 09:52:43 AM by fastbroshi »
Offline Toxic
Re: monoshock 750
« Reply #24 on: November 11, 2009, 08:13:50 AM »
Looking good.
I was just thinking the same thing.
I am looking forword to the completion of this project.
