Author Topic: monoshock 750  (Read 52788 times)
traveler
Re: monoshock 750
« Reply #100 on: August 01, 2010, 09:05:59 AM »
This bike is badass on many levels.
~Joe
Offline Roach Carver
Re: monoshock 750
« Reply #101 on: August 01, 2010, 09:19:34 AM »
marked
Offline greasy j
  • lanesplitting
  • non serviam
Re: monoshock 750
« Reply #102 on: August 01, 2010, 11:13:39 AM »
yes, ba-dass.
Offline Mandic
Re: monoshock 750
« Reply #103 on: February 26, 2011, 08:42:55 AM »
Any updates on this thing?  Interested for sure.
77 CB750F - Cafe/Daily Rider
Offline sander
Re: monoshock 750
« Reply #104 on: February 27, 2011, 03:02:22 PM »
Sadly no updates yet.... I am very busy at the moment with getting my masters degree in mechanical engineering. Any progress will be posted here.
Offline HedNut
  • Underwater Basket Weaving
Re: monoshock 750
« Reply #105 on: March 03, 2011, 06:52:05 AM »
You get your masters and then come work for me!  ;)  haha...
SOHC CB experience is a must.
Can't wait to see this bike rippin' it up!
B
Offline wannabridin
  • Patience made me a
  • -Garrett
Re: monoshock 750
« Reply #106 on: July 14, 2011, 09:20:21 AM »
bump for updates!!
Offline sander
Re: monoshock 750
« Reply #107 on: July 23, 2011, 08:20:58 AM »
You're right, i really need to get back to work on this one...
Only things left to do:
- fill up and bleed the brakes
- adjust ignition
- decide which set of carbs to use: stock (leaking) or mikuni flatslides (cool, but very dirty and i hate rejetting carbs)
- maybe fit a speedo/tach
Not even a day's work  :-[
Offline LostSoul86
    • KMA Sales, Inc.
Re: monoshock 750
« Reply #108 on: July 27, 2011, 12:10:54 PM »
Progress is progress even if it is slow  ;)
Andrew- 1978 CB750F Super Sport "Lucky 13"
Offline fastbroshi
  • Puppet
Re: monoshock 750
« Reply #109 on: November 26, 2011, 03:59:37 PM »
It's been a while, but did you ever totally finish this?
Just call me Timmaaaaay!!!
Offline bluesmoke69
Re: monoshock 750
« Reply #110 on: November 26, 2011, 10:58:59 PM »
Looking forward to a riding report!!
Offline cben750f0
Re: monoshock 750
« Reply #111 on: November 27, 2011, 02:31:29 AM »
so awesome.... looking forward to the test.
peace
Offline UYD4L
Re: monoshock 750
« Reply #112 on: February 29, 2012, 05:13:58 AM »
Has anyone ever done a single-sided swingarm on a CB750? Does anyone have any ideas which bike might be a proper fit if so? I'm thinking about doing this if possible.
Re: monoshock 750
« Reply #113 on: February 29, 2012, 06:55:46 AM »
wasnt the vfr750 single sided. I think i saw one on a cb550 once so it can be done. Thats one of those questions where the answer is, anything can be done if you have enough time and money/skill.
Offline fastbroshi
  • Puppet
Re: monoshock 750
« Reply #114 on: February 29, 2012, 03:36:03 PM »
Yes Roach, starting with the '90 VFR750, they've been single sided ever since.   I've got a '97 myself and it's a hoot.   Would someone like some measurements?
Offline Vbled1
Re: monoshock 750
« Reply #115 on: February 29, 2012, 05:26:35 PM »
NIce work, looking forward to the progress
Re: monoshock 750
« Reply #116 on: February 29, 2012, 05:45:15 PM »
Yes
http://forums.sohc4.net/index.php?topic=30008.0
Not as simple as just bolting it in though, it dramatically alters the wheelbase so lots of other mods are required to make it all work properly, front end as well...
Offline romerider153
Re: monoshock 750
« Reply #117 on: May 20, 2012, 03:17:47 PM »
I know its an older post but with a rear set setup like that wont  the shifting pattern be backwards?
Re: monoshock 750
« Reply #118 on: May 20, 2012, 04:28:14 PM »
An upside down shift pattern is common amongst GP bikes, even known as a GP pattern. Reduced the amount of hardware you have to have on your rearsets.
Re: monoshock 750
« Reply #119 on: May 20, 2012, 04:40:39 PM »
Another advantage i was told is that on corner exit if your leaned hard its easier to shift up by pressing down then to try and get your boot under the shifter
Re: monoshock 750
« Reply #120 on: May 20, 2012, 04:59:11 PM »
That too.
Offline SoyBoySigh
Re: monoshock 750
« Reply #121 on: May 20, 2012, 06:20:01 PM »
If the chain DID rub on the swinger, I suppose there's always the option of going with larger sprockets fore-and aft. Seems like plenty of room before it rubbed on the top brace. Probably a more worrisome point to rub, but still loads of space in there. Maybe just a couple more teeth up front, five more out back ... might be a tough set to find, but do-able. Just sayin' if a person were concerned that a set-up like this was unsafe because of chain rubbing, well it's still a relatively easy fix. A lot of the stock bikes had chains that rubbed, seems like a lot of CBs were designed to take chain rubbing into account, and all they had to deal with it was a little slice of steel judiciously and carefully lined up to hit the rollers and not the links, only that was in steel and not alloy. What I'm thinkin' is, whatever type of slider I put on my own arm, I'm gonna keep it in the roller area of the chain. Oh, and Gates power transmission, the guys who make those poly-chain GT carbon belt drives? They make some pretty damned small rollers. I suppose one could even use a small roller bearing with a tough outer race, mounted on a bolt off the engine block. Just my two bits.
Awesome bike, by the way.
-S.
Re: monoshock 750
« Reply #122 on: May 20, 2012, 07:01:37 PM »
thanks for clearing it up that makes alot of sence
Offline lucky
Re: monoshock 750
« Reply #123 on: May 20, 2012, 10:07:52 PM »
Looking good.
That frame looks so wimpy compared to that swingarm.  ;D
The frame is STEEL not aluminum. Aluminum has to be massive to get its strength then you have poor access to work on the bike.
The steel frame is 9 times stronger.
When you buy a $30,000 dollar Ducati you get a steel tube frame, not aluminum.
Aluminum frames are cheaper to ship.
Aluminum frames recycle easy.
Aluminum frames are easily damaged in minor accidents.
« Last Edit: May 20, 2012, 10:09:56 PM by lucky »
Re: monoshock 750
« Reply #124 on: May 20, 2012, 10:22:56 PM »
 Steel may be 9 times strondger than pure aluminum, but most steels are nowhere in trhe neighborhood of even 3 times the strength of Aluminum used on bikes today..
